Northern California Discussion board for Northern and Central California.
Do You Recommend...
Old Jan 29, 2007 | 11:37 AM
Copchaser's Avatar
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
Do You Recommend...
Putting the injector clips back in when u reassemble the feul rail?
Old Jan 29, 2007 | 01:48 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
absolutely they are needed and come in packs of 5 all the local dealerships stock them part number 17111267 also replace the rubber o rings on the actual fuel lines its like 3bucks per pack and youll need 2 of them.
Old Jan 29, 2007 | 03:26 PM
Copchaser's Avatar
thanks for ur input.. I appreciate it.
Old Jan 29, 2007 | 09:18 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
why would you not put them in?
Old Jan 29, 2007 | 10:06 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
Put them in. I am sure that you do not want to have a car-b-que due to a gas leak.
Old Jan 30, 2007 | 02:10 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
I've ran / am currently running with no injector clips on HSR and TPI.
No "CAR-B-Q" worries, that's what the fuel rail bolts are for.
djmarch
Aftermarket Product Review
Oct 10, 2011 04:36 PM
Brian K
Sep 23, 2001 04:16 PM
[-sLaYeR-]
May 29, 2001 06:45 PM
