A few ?s on my TPI for NO. CAL
1 Post
Car: '88 Camaro
Engine: 5.7 L98
Axle/Gears: Borg Warner 9 bolt w/3.27 lim. slip
I've been spending more time and $ on my '54, so I haven't been around here lately. I had a ? on my IROC though. I posted this in the TPI section, but you locals always seem to give me a quicker response.....
https://www.thirdgen.org/forums/tpi/...ml#post3404723
Thanks for your time. Daniel U
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
Re: A few ?s on my TPI for NO. CAL
you adjust minimum air(idle screw/IAC) first then the TPS
1 Post
Car: '88 Camaro
Engine: 5.7 L98
So the TB blades should be almost closed? Why is she back firing?
1 Post
Car: '88 Camaro
Engine: 5.7 L98
I got the TPS and IAC set. I think I still may have a small vacuum leak I need to address. I'm going to try to get some data logging in soon. I also need to get the exhaust leak fixed. Thanks for the help guys. Daniel U
The_Phoenix
09-03-2015 10:56 PM
Sanjay
08-12-2015 03:41 PM
