Northern California Discussion board for Northern and Central California.
Smog question
Old Aug 6, 2007 | 11:14 PM
80sBaby28's Avatar
Car: 1989 camaro
Engine: v8 fuel injection
Transmission: automatic
Smog question
Hi i was wondering when i get a smog check will they fail me because i have a check engine light on. I have a 305 that used to have tbi and the owner before me made it into a carb. engine. So the check engine light is because of the wiring but the car runs fine. thank you
Old Aug 6, 2007 | 11:22 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
Re: Smog question
yes, and you can fail because of the carb.
Old Aug 6, 2007 | 11:42 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Smog question
You will fail because of the carb'ed engine and with the SES light on. TBI was 88-92, and carb was 82-87. There were no carb'ed engines at the same time as a TBI, and you cannot go backwards with engines. You'll need to change it back to a TBI, or to a TPI.
Old Aug 7, 2007 | 12:12 PM
north_oakland's Avatar
Car: 1989 Camaro
Engine: 2.8L
Re: Smog question
Cant you just say that you put a new engine in the car, if you get the Check engine light to go away? Wouldn't that be ok to pass smog?
Old Aug 7, 2007 | 01:00 PM
80sBaby28's Avatar
Car: 1989 camaro
Re: Smog question
Is it easy to put a TBI or TPI back in the car?
Old Aug 7, 2007 | 07:01 PM
80sBaby28's Avatar
Car: 1989 camaro
Re: Smog question
can this work?
Old Aug 7, 2007 | 08:36 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Smog question
You cannot put an older engine into a newer vehicle and you cannot downgrade your engine meaning you cannot go from a v8 to a v6 but you can go v6 to v8.
Old Aug 7, 2007 | 09:02 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Re: Smog question
80sBaby28, do yourself a big favor and get your car "right" before you try to smog it. Make sure to find a shop that will "pre-test" it for you so you know before you are hooked up to DMV that you will pass.
Old Aug 7, 2007 | 11:45 PM
kairles's Avatar
Engine: 383/LGX
Re: Smog question
Not true, you can put just about any motor you want. Motor has to be newer than the chassis, and you can't put a heavy duty motor in a passenger/light duty car/truck. You can't put in a motor that will degrade the emissions, basically it has to burn the same as or cleaner then the motor its replacing
Also seller is responsible for smog. "as-is" will not save them.
Old Aug 7, 2007 | 11:57 PM
Kevin91Z's Avatar
Re: Smog question
No, because the carb setup is older than what came on his car from the factory. You cannot put an older setup on a car. You can only go the same year or newer.
Your choices are Camaro/Caprice TBI, Camaro/Corvette TPI, LT1, or LS1.
Old Aug 8, 2007 | 11:16 AM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Re: Smog question
Cracks me up how many cars are sold private party only to fail smog. A lot of buyers just don't think about this when they see the hotness of a sweet car.
That guy I saw in the Denny's parking lot had a Camaro with a shiny new intake but all the smag equipment was gone. He didn't know the seller was obligated to show the car could pass smog.
Old Aug 8, 2007 | 11:33 AM
koolctk's Avatar
Car: 1989 Trans Am GTA
Re: Smog question
To Cadillac and Kairles, What do you mean when you say that the seller is obligated and responsible? Do you mean legally? I have talked to DMV and asked them and they say as long as buyer and seller agree that there doesn't need to be a smog (as is) then its fine.
Old Aug 8, 2007 | 07:22 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
Re: Smog question
koolctk,
Not true. The seller is responsible for somg as long as the car is running and it is not a race car. If the car is registered the seller is responsible.
UnderCover89TBIYou cannot put an older engine into a newer vehicle and you cannot downgrade your engine meaning you cannot go from a v8 to a v6 but you can go v6 to v8.
UnderCover89TBI,
Your correct yet incorrect. Way back when these cars were new there was a loophole in the smog laws that was corrected in March of 1983. I know because my car is an example of this loophole. Prior to March of 1983 if you changed your engine the car was smoged to the year of the engine not the year of the car. My 1982 is smoged to the year of the motor that I installed. I installed a 1970 LT1 engine in my 82Z in 1982 and now it uses the smog for a 1970 high-po engine. I had a BAR sticker put on my car in March of 1983 and it will be that way for life. I was told at the time in 1982, that my car is porbably the only car like that in CA.
If you do an engine swap after that date your correct that you must have smog of the same year or newer.
Old Aug 8, 2007 | 09:22 PM
Cadillac's Avatar
Re: Smog question
http://www.dmv.ca.gov/vr/smogfaq.htm#BM2537
Old Aug 8, 2007 | 10:18 PM
koolctk's Avatar
Re: Smog question
Although it says the seller is responsible, whats the consequence if they dont, especially since it happens all the time.
Old Aug 8, 2007 | 10:56 PM
Comp788's Avatar
Re: Smog question
Depends on how ugly you want it to get. I have seen people take the seller to court and collect as much as the car was sold for and still ended up getting to have the car.
The bottom line on selling a car that is not smog legal is, you better know who your selling the car too. Otherwise you could be on the hook for making the car legal. No matter what it take to make it legal.
Of coarse there are exceptions (lean sales, repo, and race cars)
Re: Smog question
Mike thanks for the link!
Old Aug 9, 2007 | 11:14 PM
Kevin91Z's Avatar
Re: Smog question
Originally Posted by Comp788
UnderCover89TBI: You cannot put an older engine into a newer vehicle and you cannot downgrade your engine meaning you cannot go from a v8 to a v6 but you can go v6 to v8.
I dunno about that one. You can definitely put an '87 turbo V6 from a Grand National into any '87 and older car. You can even put an '89 Turbo Trans Am setup into any '89 and older car. That's going from a V8 to a V6. It is my understanding you can change any car engine to any other car engine, as long as its from the same year as your car or newer. But you cannot swap truck engines into cars. I think you can swap car engines into trucks, but I'm not sure.
Old Aug 11, 2007 | 02:39 AM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
Re: Smog question
I always thought if you put a older motor in your car lets say an 89 turbo in a 90, you have to pass the 90 emission requirements with the 89 turbo motor
Old Aug 11, 2007 | 03:36 PM
Cadillac's Avatar
Re: Smog question
I've made deals with buyers before stating they were responsible for the smog test fees. It can be just another negotiating point. Now if the car fails smog, the buyer needs to be given the right of refusal (for obvious reasons). That whole scenario is not sanctioned by the state but all I think they really care about is the emissions and registration. Gentleman's agreements with unknown parties can be risky and could end up like Brett mentioned with the buyer getting the car for free. For least risk, smog it yourself.
Old Aug 11, 2007 | 05:30 PM
Kevin91Z's Avatar
Re: Smog question
No, you cannot put an older engine into a car, period. The '89 TTA engine didnt come in '90+ so you cannot use it on a street vehicle.
Old Aug 12, 2007 | 02:17 AM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
Re: Smog question
Roger
Old Aug 28, 2007 | 02:47 AM
ta3ff's Avatar
Car: '89 Camaro RS
Engine: none
Transmission: none
Axle/Gears: 4th gen 3.42 posi
Re: Smog question
80sBaby28, where do you live? If your in the Fresno area, you can have one of my TBI intake with the TBI. I think I have about 3 of them. I'm switching over to TPI and yes it will be smog legal.
Old Aug 29, 2007 | 01:28 PM
thedoctorisin's Avatar
Car: 79' LT1 olds cutlass/ 87' IROC
Re: Smog question
i would say your best bet aside from changing the car back to its original form would be to find a "hole-in-the-wall" smog shop thats more concerned with moving its customers in and out the door. if everything looks normal, ie. no ses light and it actually passes the tail pipe test your probobly ok. the key is finding the smog shop the doesn't care about the little things. you should have a good gas cap, cat.,all the pcv should look intact, egr. as long as it looks legit and assuming it will actually pass your in good shape.
Old Sep 4, 2007 | 03:56 AM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
Re: Smog question
here's something some of us would do for smogging. IF the car isn't in your name yet, Go down to the DMV and register your car, paying for all the DMV fees, and then at the same time place the car on a 'Non-Op'.
You will need to have it registered in an unincorporated area that only requires a smog test upon purchase and upon sale; not the bi annual areas. Once the vehicle is on non op and you've recieved the title from the DMV, wait a couple months and then go take the car off of the non-op. You will then not have to pay or produce a smog test. It's a little known loop-hole and I used to use it a lot. The key is finding someone or a place in an unicorporated area.
If you've had the car for awhile, it's going to be difficult to prove to the smog police that you didn't modify the engine yourself afterwards.
Do you want to keep it? Can you afford to convert to TBI? Will it be time soon for a new engine anyway?
If you want to resell it, be sure to get a signed contract from the buyer that he is aware that he is purchasing a part's only vehicle, or one designed for off road use only.
Can you give us some specifics on when/how/where you made the initial deal????? Nitro
onefreakz
May 14, 2018 12:15 PM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
redmaroz
Aug 16, 2015 11:40 PM
jackhammer
Aug 15, 2015 10:04 PM
mustangman65_79
Aug 7, 2015 09:55 PM
