Northern California Discussion board for Northern and Central California.
Added BBK pulleys
Old Aug 8, 2007 | 12:58 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
Added BBK pulleys
had bennie install them for me. It seems temps and charging are same as before. No lets see if they drop my ET
Old Aug 8, 2007 | 02:27 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Added BBK pulleys
If your times drop, I know what I am getting next
Old Aug 8, 2007 | 07:18 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
I doubt you'll see much of an et drop, maybe a few hundreths of a second maybe if your lucky a tenth. But id like to know too..are those made for vehicles with stock amperage needs? or high amperage needs?
Old Aug 8, 2007 | 09:59 PM
kairles's Avatar
Engine: 383/LGX
best so far tonight is 14.8@93. It feels faster just need the car to be a little cooler running at 220*
Old Aug 8, 2007 | 10:53 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
Put a 160*-180* t-stat in it.
Old Aug 8, 2007 | 11:01 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
Don't go too cold or the computer sensors will be out of the proper range. If the temp is too cold the computer will incorrectly adjust the fuel and it will be out of tune. If you have a chip burnt to rectify the issue you won't have any issues.
Old Aug 8, 2007 | 11:11 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
When I had a 160 in mine, it would stay right at 190* all day. Although I thinki t may not be hot enough now for a 160.
Old Aug 8, 2007 | 11:16 PM
66impalaTPI's Avatar
Car: 96 impala
Transmission: 4L60e
hey kairles, after adding the bbk pulleys, are your car's headlights dimmer and instrument panel dimmer. pros and cons?
Old Aug 8, 2007 | 11:43 PM
kairles's Avatar
Engine: 383/LGX
nope everything looks the same. only thing different is the volts sit just under 13 at idle with lights on and the radio.
car was running at 220* because the line was moving hella slow. usually it never even gets to 220* unless Im in heavy traffic
my butt dyno didn't lie.
1st run-15.1@93.1mph
2nd run-14.8@93.5mph
3rd run-14.8@93.9mph
last run I spun real bad off the line and halfway through 1st gear.
I have a 160* stat waiting to go in
Old Aug 9, 2007 | 12:12 AM
Car: 96 impala
Transmission: 4L60e
awesome. let me know what happens when you install the 160 *.
Last edited by 66impalaTPI; Aug 9, 2007 at 12:13 AM. Reason: Automerged Doublepost
Old Aug 9, 2007 | 02:41 AM
1TUF92Z's Avatar
Car: 92Z28,91Z28,91Z281LE,95ZR-1,08Z06
Engine: 406, 350, 305, 350, 427
Transmission: auto, auto, 5-speed, 6spd, 6 spd
Axle/Gears: all stock
those pullies are designed and set-up for street use. if your plan on running hi output stereo amps them i would not recommend any u/d pullies at all. that set-up has a little effect on the cooling system on a stop and go traffic but not enough to make it overheat assuming other cooling system components are in proper order. i use race pulley and that one is not recommended for street use but i had it in my car since 94. it worked fine for me as long as you don't stay stopped for 10 minutes or else it'll overheat. made quite a difference though in acceleration department.
oh by the way, you should put a shiftkit and should gain 2-4 tenths. pizza cutters can also gain UP to 4/10 of a sec.
Old Aug 9, 2007 | 11:23 AM
kairles's Avatar
Engine: 383/LGX
yeah thinking about getting a B&M just because I can get it for cheap.
what are pizza cutter? you talkin about skinnies up front?
Old Aug 9, 2007 | 06:39 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Transmission: stage2 700r4
Axle/Gears: 2.73 for now
what were your times before the pullies??...how much were they and where did u get them from?
Old Aug 9, 2007 | 09:53 PM
kairles's Avatar
Engine: 383/LGX
times were about the same(15.0-14.7) but my MPH was 91 to low 93. I know if the car was a little cooler I would have had some lower ET's.
I got the pulleys from Kragen(I work there). think they sale for about $190 but I had them price matched to summit. I paid $139.95+tax
Old Aug 9, 2007 | 10:27 PM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
With adding pulleys, does it help to add a higher amperage alternator? Such as going from a 100amp to a 160amp????? nitro
Old Aug 11, 2007 | 03:11 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
you never said what you ran before the pulleys...
Old Aug 11, 2007 | 05:24 PM
kairles's Avatar
Engine: 383/LGX
sure I did
Old Aug 12, 2007 | 12:53 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
I need some learning here.
How is it that the pulleys could imprve times? What is the engineering that I need to understand that explains the idea here?
Old Aug 12, 2007 | 01:50 PM
koolctk's Avatar
Car: 1989 Trans Am GTA
The pulleys should improve times (although only slightly) because there is less parastitic loss of energy through the pulleys, allowing the engine to make more power and pull through the RPM's more freely(accelerate through the RPM band faster than it did before). I think its just physics. Someone please correct or support me on this one.
Old Aug 12, 2007 | 03:57 PM
JesasaurusRex's Avatar
It just spins things slower
Ed1LE
Sep 30, 2018 09:14 AM
KCG
Mid-Atlantic Region
Oct 25, 2015 06:57 AM
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Oct 3, 2015 01:25 PM
