block filler
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
block filler
Anyone familiar with this stuff locally?
Popped a minor hole in my water jacket tonight doing the final clearancing for my rod bolts, right under the oil pan rail.
I think I will check tognottis for a block filler, just use enough to fill the hole, so I wont chance distorting my cylinder walls.
Also heard of good stuff called devcon, anyone know of this stuff?
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: block filler
When I lived in CA we used Belzona a lot. I used to use it to rebuild worn out counterbores in the bottom of diesel truck engine blocks. We could actually machine it like it was cast iron after we put it in. Made the block re-useable and we ran a lot of miles on those engines, hard miles, and never had a failure from that.
We also used it to fix an old CAT block on the outside from a freeze that broke the water jacket. It was running when I left in a bulldozer for 2+ years...
Car: '88 Iroc
Axle/Gears: 3.45
Re: block filler
this stuff is pretty pricey. there's a kit on ebay much cheaper here.
unrelated: i saw the thread on your illness, travis. i wish you all the best and a hearty 'get well soon'!
skinny z
Oct 5, 2015 06:23 PM
