Northern California Discussion board for Northern and Central California.
350 build machine shop?
Old Feb 10, 2008 | 07:10 PM
dspencer24's Avatar
Car: 91 z28
Engine: 350/ported accel tpi/AFR 195
Transmission: t-5 =(
Axle/Gears: 345
i just got a used complete L98 motor and i want to start taking it apart rebuilding it. I would like the block cleaned painted and looked over. Does anybody know a decent machine shop that could do that. Also should i have the bottom end redone completely or just have it checked out and maybe get new pistons? Im going to be going with the zz4 cam as well
Old Feb 10, 2008 | 11:59 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
Re: 350 build machine shop?
guy can come off wierd or an ******* but he has good intentions and knows his **** does great work been dealing with him for 6 years
roseville engine machine
916-782-3703 collin is the owner speak to him
hes not the cheapest or most expensive about middle if you pay cash you get the long deal than.
tell him eric sent you
Old Feb 11, 2008 | 12:36 AM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
how much am i looking at spending?
Old Feb 11, 2008 | 11:40 AM
1TUF92Z's Avatar
Car: 92Z28,91Z28,91Z281LE,95ZR-1,08Z06
Engine: 406, 350, 305, 350, 427
Transmission: auto, auto, 5-speed, 6spd, 6 spd
Axle/Gears: all stock
Gotta give us more info on the motor. How many miles does it have? What year is it? Was it in running condition when pulled out? You can do a leak down test. If leak down test shows good numbers then short block should be good. If it has 60k+ miles, i would get the heads freshen up. The valve seals tend to go bad and while you're at it replace injector as well if they are stock. Buy the Ford SVO injectors.
Old Feb 11, 2008 | 01:58 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Matters where you go and what exactly you want done.
If you want just machine work on the block, I have got cheap as $500.
If you want a full rebuild of your motor, break out the checkbook, $1500+.
Old Feb 11, 2008 | 04:45 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
oh sorry for the lack of info. The engine was from a 92 z28 with 105 000 miles. the guy got a lt-1 and swaped it. He said the engine was working perfectly fine and pulled strong. I bought everything for 450 $. I want to make 300 hp at the wheels if posible. And i would like to have a zz4 cam. which means head work correct? other then that im not to sure what else i should do.
Old Feb 15, 2008 | 01:01 AM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
doers anyone know anyone else
Old Feb 15, 2008 | 10:15 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
guy is alil weird likes to talk .. thanks
Old Feb 19, 2008 | 01:12 PM
valencia1z's Avatar
Car: 1986 IROC-Z
Engine: 350 5.7 TPI
Transmission: 700R4 2500 stall
u just need a short block im planing on redoin a set up for mines and im going a lil diffrent but i have some good stuff im going to be pulling out of mines a steel nitride crank pink rods je forged pistons not the srp ones im in stockton and i have the block already identical to mines a 880 1 piece rear main block i already had the block cleaned doesnt need to be bored i was going to have it assembled im just trying to buy conecting rods and pistons for mines and all the parts are fine im still running them in my car how fast u trying to go i even have a cam for it im just going bigger all these parts have maybe 15000 miles and my combo passes smog and i can drive it to the track knock off 12.5 and it was 8.0 compression with my heads and drive it home and thats just on motor ill be freshened up as in new bearings honed pump numbers 209)271-5305
my cams a comp cam xr-276 hr
Last edited by valencia1z; Feb 19, 2008 at 01:15 PM. Reason: Automerged Doublepost
Old Feb 19, 2008 | 01:21 PM
valencia1z's Avatar
Car: 1986 IROC-Z
Engine: 350 5.7 TPI
and if u want to see it run im usually in sac weds nights or the summit series on weekends
Jake_92RS
Jan 28, 2020 10:37 PM
italiano67
Dec 11, 2016 09:21 AM
Cameeeero
Sep 18, 2015 04:00 PM
Reborn756
Sep 4, 2015 03:42 AM
sreZ28
Aug 14, 2015 07:48 PM
