Northern California Discussion board for Northern and Central California.
borg warner 9 bolt rear end caliper to caliper $175
Old Mar 5, 2008 | 01:22 AM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
please take this thing away, letting it go for a steal $175 will deliver for gas money upto 150 miles from sacramento,
this axle is as complete as it gets it has attached, swaybar, control arms, pan hard bar, end links, rotors, brake calipers, e brake cable, ready to just bolt in an go, its out of an 87 iroc with a 3.08 ratio yes it is posi trac, 9 bolt heavy duty 3.75 ring gear,
as all of you know
Old Mar 5, 2008 | 02:12 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Transmission: stage2 700r4
Axle/Gears: 2.73 for now
Re: borg warner 9 bolt rear end caliper to caliper $175
you think there will a difference between this and non posi 2.73 10 bolt in terms of acceleration?
Old Mar 5, 2008 | 10:32 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Yeah... one word: TRACTION.
The gear difference may not be that much of a difference to notice but if the posi is in good shape (is is Eric?) that and the rear disks make it totally worth it.
Another thing, you'll need a different proportioning valve to run the rear disks if you are running drums now.
Old Mar 5, 2008 | 11:35 PM
1TUF92Z's Avatar
Car: 92Z28,91Z28,91Z281LE,95ZR-1,08Z06
Engine: 406, 350, 305, 350, 427
Transmission: auto, auto, 5-speed, 6spd, 6 spd
Axle/Gears: all stock
it's off of an 87 so it's the cast iron calipers and smaller rotors than the 89-92 J65 brakes.
Old Mar 5, 2008 | 11:59 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Is it a 2 series or 3 series?
Old Mar 6, 2008 | 12:38 AM
porkyzilla's Avatar
Engine: 5.7tpi 350,
although its a 3.08 gear its still a 2 series carrier,
only 3.27 and 3.45 has the 3 series carrier
Old Mar 13, 2008 | 11:00 PM
bigfosty2's Avatar
Car: 1988 Chevrolet Camaro IROC-Z
Engine: 350tpi
If you still have it, I will probably take it. I would just need to figure out a way to get it home.
hectre13
Dec 11, 2023 08:14 AM
theshackle
Sep 17, 2020 08:26 AM
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
