Hmmm.
Car: '88 Camaro
Engine: 5.7 L98
Axle/Gears: Borg Warner 9 bolt w/3.27 lim. slip
Re: Hmmm.
My Harwood hood fit great, but it even wears funny at the top of the firewall. Is it a fiber hood or steel?
Car: '88 Camaro
Engine: 5.7 L98
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Car: 88 gta
Engine: 350 tpi
Re: Hmmm.
I was just playing with ya, can you get exauset tubing u bends and make your own ducting? Or mock it up with abs from home depot, and take it to a exaust shop to fabrocate?
Car: '02 Z06
Engine: L33 5.7
Re: Hmmm.
I think a peice of 3" pipe at 120degrees or so should do the trick, then i have to cut a hole in it and weld the surge valve in place.
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Re: Hmmm.
They both are used to vent the excess air out of the discharge tube so you do not get compressor surge.
A surge (bypass) valve recirculates the compressed air back into the intake, a bov releases it into the atmosphere.
I think a bypass is more than a BOV that recirculates though. You can vent a bypass to the atmosphere and that doesn't make it a blowoff valve. It remains open by vacuum. When the vacuum goes away, then the valve closes. That's not exactly how a BOV works, as it's not opened all the time.
Car: '88 Camaro
Engine: 5.7 L98
Car: 87 GTA
Re: Hmmm.
If yur charcoal cannister is gone, run the tubing out there, to pull cooler air in from under there.
Relocate the battery if the other side is easier to get to.
A TPI filter tubing Y-pipe won't work?
Car: '02 Z06
Engine: L33 5.7
Re: Hmmm.
Ok, let me lay out the scenerio for you, From the back of the procharger, the intake tubing is 4" diameter on this model. A tpi Elbow would be a restriction. I had to relocate my brake lines just to make the 90degree off the 'charger. I cannot wrap 4" pipe back over my charge pipe, hood clearance just wont allow it, and I cannot go around the 'charger on the right either, master cylinder clearly in the way, I tried going under the procharger, but between the framerail and charger is only about 3" if that.
Car: 87 GTA
Re: Hmmm.
Could you go straight back, through the firewall, just to the right of the wiper motor,and fit your filter in the cowl area?
Just trying to think of a way to get cooler air.
Car: 87 GTA
Re: Hmmm.
RA hood style filter, to use the Cowl Induction hood as a true cowl induction?
Across the engine, between the TB & Dizzy, 90 deg turn forward, then to the battery tray?
Car: '02 Z06
Engine: L33 5.7
Re: Hmmm.
I've looked into the RA filter, but the outlet it still too small. i cant run anything farther back to the firewall, my proportioning valve and linelock, along with brake lines in general are in the way, brake booster too.
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
Re: Hmmm.
maybe use their cobra head elbow and a 45* elbow to place the filter behind the hat closer to the cowl opening.
92GTA
Classified Ads Feedback Board
Feb 14, 2015 04:01 PM
