S'more Toys
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Re: S'more Toys
are you going to have that installed by March 20th?
Car: 91 Pontiac Firebird
Engine: Killer SBC, w/ RV cam
Transmission: AutoMatic, w/ shift kit
Axle/Gears: Posi-Traction
Re: S'more Toys
The Gen7 has a 2 step circuit, so the Transbrake will be wired into that so launch RPM's are set at a desired RPM, so all I have to do is "arm" the brake, hold the button, & floor the gas pedal.
When activated the Gen7 will fire every other cylinder until I let off the button. The transbrake engages 1st & Reverse until the button is released.
When released the car should either spring off the line or shatter something. haha
Hotrodboba400
Dec 10, 2019 07:07 PM
xbmx89
South Central Region
Oct 31, 2015 10:59 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
