Nor-Cal 2010 - 1/4 Mile Track Times - Get on the list!!
#51
#52
Car: 91 Pontiac Firebird
Engine: Killer SBC, w/ RV cam
Transmission: AutoMatic, w/ shift kit
Axle/Gears: Posi-Traction
Re: Nor-Cal 2010 - 1/4 Mile Track Times - Get on the list!!
Well I went out for the TNT today. Timing was the only thing I changed.
I was lucky enough to have both Rex & Glen Hutchinson, Theo from Wizard Racing, and Artie Pavia all out there all watching and trying to help me out .
The run is the fasted so far, though the ET is lower, the MPH is a little faster. Not as low of an ET as I'd like.
11.337 @ 126.660
Everyone seemed to have the same opinion, either loosen up the converter to get it to Flash in the powerband or add the bottle and leave it alone.
11.337 @ 126.660
#54
3500 Footbrake, 1.66
4300 Transbrake, wot, 1.66
Heres an in-car shot, you can see at take off, the rpms dont do much until about 5500, then when shifting the rpms drop almost 2000 rpms before recovering.
http://www.youtube.com/watch?v=pY-6H...eature=channel
#55
Car: 92Z28,91Z28,91Z281LE,95ZR-1,08Z06
Engine: 406, 350, 305, 350, 427
Transmission: auto, auto, 5-speed, 6spd, 6 spd
Axle/Gears: all stock
WOW!!!! Nice video.
#56
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Sounds Healthy Marc!
#57
Car: '82 Z28
Dang, shifting to 3rd right before the line? I'm in 3rd right around half track. I think it's time to try out the nitrous to see if it wakes that thing up.
http://www.youtube.com/watch?v=8HJx6QdxzZQ
#58
have you left off idle yet? won't seriously fix the 60 that's for sure but every car likes something else.
I'd hit it with the kit and see what it does, honestly i'd tell you not to worry about it if you had a glide in the car, but even though it's a nitrous car it should 60 better than that on the motor with a 3 speed. I think my car went 1.47/1.48 on the motor when i had the turbo350 in her. Oh well, throw some bottle at it and tell us what happens. Good luck.
#59
Thanks for the the compliments.
Bottle is in & making changes to have the Gen7 change the timing & AF map so when the preset RPM & WOT come together, its party time.
Thanks Jess.
Thanks Jess.
#60
#61
11.33 @ 126.66, 1.6 60'
#64
Car: 1983, 1986, 2001 Trans Am
Engine: 305 cfi, 350 carb, LS1
Transmission: 700,Edge 2800 th350,Edge 3400 4L60E
Axle/Gears: 9 Bolt 3.27 Borg-Warner, built 3.73
ran 3 time this week and was at constant 15 flat was hopin to break into the 14s but no luck this time
#66
its an auto and my reaction time on my last run was .17 but was my worst down the track at 15.033 i believe
#67
86 was a bad year for the 305. Can't be helped with that peanut cam in there. 15 flat is not all that bad considering how much it weights and only putting out 190hp. I'm sure some simple little mods like cutting the air box or less restrictive intake would help you crack that 14.99 barrier.
#68
i think i got the 85 cam my rpm start red at 5500 and i got 1.6 rockers to kinda wake it up a bit and ported out the plenum and upper runners but yea was only my first time out there http://www.youtube.com/watch?v=fYsolNm3p4w
#69
86firebirdta, norcalz28, UnderCover89TBI,
Come on guys, this is not the Shoulda Coulda Woulda post. Post what you ran, good/bad etc.
#70
Engine: gone
Transmission: gone
Axle/Gears: gone
no different then you talking about your nitrous and flash rpm and what your going to run . if thier was a problem im sure our moderator would tell us something
#71
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
I know some of ya must have some times you want to post.
#73
I bought a shirt a year or two ago that says "I'm not cocky, I'm just faster that you"
I guess I'll be sporting it a little more often.
3rdBird - 10.193 @ 136.440 - 1.394 60' - 1991 Pontiac -TRANS F*CKING AM 406 -Nos
#74
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
There you go Marc!!! Nice Run! So when are the 9's coming?
#75
Car: '82 Z28
That's moving out better Congrats!
#76
Thanks, going out this Friday & try to at least back it up, maybe do I dare say, get into the 9's...
#80
That's true. Hahaha. I have been busy lately but Jolly is at Autostart. I gave one of my customer(who has a clean 68 Camaro) a ride around the back street and few minutes later, Elk Grove Police was circling the premises. I had to bring Jolly inside the smog bay and shut the roll up door down.
#81
Back to your street racing roots huh? Be care, would be a shame to see Jolly get impounded.
#82
Car: Camaro RS/SS
Engine: 5.7 LS1
#84
We'll be going out to the Chevy vs Ford on Saturday.
Its open to all Chevy powered, or Chevrolet vehicles.
Just installed a 125 jet & added some more timing, so we'll see what happens.
#85
Hey cool Marc we will have to look for you, I will be out there also running my sons black 91 Z28
#86
#87
Car: 83 z28/ 82 trans am
Engine: stock? 305 w/crossfire
Axle/Gears: 3.73/stock 2.98?
Wddavis 1/4 16.173@83.91 60' 2.312 82 Trans am stock 305 crossfire injection stock 200c transmission.
#89
#90
Car: 83' Camaro Z28
Engine: 305 V-8 CrossFire
Transmission: 700-R4
No I didn't run my car for a couple of reasons. The rear end (373 gears) Walter put in jacked up my shift points! So to remidy this the FUN WAY!! Were putting in a T5 tranny, just waiting for the $$ to buy a clutch!!
Besides I did NOT want this happining to me:http://youtu.be/iG_t_XOmBI8
#91
If you plan to run the car a lot at the track you will want the auto. Tell Walter to not feel bad it takes awhile to get good on the tree!
#92
Car: '82 Z28
Excuses excuses, run your car and have some fun
#96
Joey, I have a couple bottles you can borrow, should shave about a second off you time.
#97
Car: '89 GTA
#99
Got jokers here on the board..LOL I'll claim my spot in a month.
