Northern California Discussion board for Northern and Central California.
Would I be able to get my Formy Refereed with an Lq4 swap with all Ls1 emissions?
Old Sep 9, 2010 | 08:24 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Is it a legal swap? Im assuming its not as it is a truck block. Do the refs look at the block numbers? Would it be easy to sneak it through and get it refed? I know all it would take is a magnet to notice its not right.
Old Sep 9, 2010 | 09:26 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Re: Would I be able to get my Formy Refereed with an Lq4 swap with all Ls1 emissions?
I can't answer the question if they look at block numbers, or sneaking through, but from a CA legal swap standpoint, no, I believe you can not use a Truck engine in a Car and/or a Car engine in a Truck (something about the gross vehicle weight).
If by some chance it's not a problem and you're putting LS1 parts, you will need all of the original equipment that came with it; EGR, AIR, 4-O2s, CATS, PCM, Sensor (Gas tank pressure) and anything else that is related that could throw a CEL code, not to mention CARB #'s for all your aftermarket stuff.
Old Sep 9, 2010 | 09:40 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I am lost at which route I want to go engine wise. I lean towards LsX for power and reliability, but look at 383'S and porting my heads for ease of swapping, but suffer reliability and gas mileage.
Old Sep 9, 2010 | 11:06 PM
Car: '89 GTA
Seems to me that those 2 items are out the window once you get serious about modifying and racing an older car.
A 2nd vehicle for a DD almost becomes a necessity for reliability and really good mileage. Don't get me wrong I'm all for LSX swaps obviously, but not for mileage, or reliability per se.
I drive my 4th gen to work everyday. The 17-18 in the city ain't a big deal, although the highway mileage is decent in the mid-low 20's. Probably better once I tune it.
Old Sep 9, 2010 | 11:16 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Well your deffinately sacrificing fuel mileage with a carb setup. But carb's provide better HP numbers so yeah. Is cost a problem? It'd be cheaper to do a carb 383 with some AFR's 220 cc. 10 mpg if you are lucky...
Old Sep 10, 2010 | 12:24 AM
3rdBird's Avatar
Car: 91 Pontiac Firebird
Engine: Killer SBC, w/ RV cam
Transmission: AutoMatic, w/ shift kit
Axle/Gears: Posi-Traction
I'm doing a 6.0 swap on my 78 Trans Am. The only ID #'s on the L blocks will be hidden by the trans. You can call it what you want but, what ever year/engine it is has to have that years smog equipt.
The fuel tank and evap is going to be the biggest problem.
Old Sep 10, 2010 | 12:36 AM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
Originally Posted by UnderCover89TBI
But carb's provide better HP numbers so yeah. ...
I'd have to disagree. Carb may make more HP than a TPI, but apples to apples think F.I. would produce better numbers due to more precise tuning.
Old Sep 10, 2010 | 12:58 AM
Car: '89 GTA
Old Sep 10, 2010 | 01:24 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
...or worse numbers thanks to imprecise tuning / lack of tuners
Carb. So easy to tune, a caveman could do it.
Old Sep 10, 2010 | 05:10 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I was reading up on some ref stories, and I find most DO use a magnet to check. They can't take stuff off your car to check and whats in the way is in the way. But I have heard quite a few horror stories involving magnets and LsX stories.
Old Oct 3, 2010 | 01:08 PM
Brendan91Z's Avatar
Car: 1991 Camaro RS, 2013 Camaro SS 1LE
Axle/Gears: Stock
I just saw a guy the other day in this mean 00 WS6 and I knew that thing wasn't stock so I asked him what he had and he did the LQ4 swap with LS1 accessories I believe but a different intake. I also asked him if he was able to pass smog still and from what he told me there is no problems.
Old Oct 3, 2010 | 01:27 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Well they have no reason to check his block right? It looks like its an LS1 in there still. I dont know why you'd get rid of the aluminum block for a steel block. He wanted the steel block because it was easy/cheaper to modify or something? I dunno. But as far as visual. They'd have no reason to check it at a normal smog station.
Old Oct 3, 2010 | 01:28 PM
wyochimneysweep's Avatar
Car: 92 chevy 1/2 4 wheel drive
Engine: 5.0L with TPI
my understanding is you can swap a newer engine into a older car as long as all the diagniostics work and have all the emmissions equpiment installed.
Old Oct 3, 2010 | 01:32 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
The problem he is having is that you have to use the exhaust and evap system off the truck/vehicle the engine came out of. So I am not sure on where the evap canister. But Ramair21 had to use the 4th generation fuel tank on his Ls1 swap. It'd be hard to put a truck fuel tank into a camaro if he had too. Again I dont know all the rules myself, but I believe those are some.
Old Oct 3, 2010 | 11:52 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Who says you have to do anything?
If it looks like it is the right one, it should skate, no two refs are the same.
Old Oct 4, 2010 | 02:08 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
I agree. If it passes the emission test and has all the necessary hookups, shouldn't be a problem.
Will
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
sreZ28
Aug 14, 2015 07:48 PM
reiderz iroc
Aug 13, 2015 04:57 PM
