Northern California Discussion board for Northern and Central California.
Project Winter Storm
Old Jan 22, 2011 | 01:19 AM
  #101
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: Project Winter Storm
its just they are sooo bulky.
the flex a lites are much more compact, and flow better!
Old Jan 22, 2011 | 02:24 AM
  #102
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
Originally Posted by 3rdBird
I live my life a 1/4 mile at a time, in those 10 seconds or less..........
sorry I had too
Old Jan 22, 2011 | 10:15 PM
  #103
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Well... ive been busy today. Engine is out. Notched the K-member for the A/C compressor. Here are some pics
Found my oil leak
Old Jan 22, 2011 | 11:28 PM
  #104
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Looking good joey. So on that piece you cut out of the frame. Do you leave it open like that or do you recess some metal back into it and weld it up?
Old Jan 23, 2011 | 12:00 AM
  #105
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
I still got to weld it up.
Old Jan 23, 2011 | 10:19 AM
  #106
Copchaser's Avatar
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
Lookin good man.. good to see progress. Now on that piece u notched out, how much of that gets re-welded. I'm tryin to picture the finished product.
Old Jan 23, 2011 | 09:07 PM
  #107
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
This is not mine. But its going something like the picture
Old Jan 23, 2011 | 11:59 PM
  #108
Engine: gone
Transmission: gone
Axle/Gears: gone
That's exactly how I pictured it!
Old Jan 24, 2011 | 12:30 AM
  #109
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
having that new child must have hurt your budget eh joey, I would have figured you would just of sprung for that new tubular piece you did everything else just ****..
Old Jan 24, 2011 | 09:35 AM
  #110
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Oh yeah bro. I cant even imagine how much more expensive she will be once she gets older. Thats why im doing things right now while she is still cheap and small. Plus even with the tubular k-member, i dont think my Air bags would work. because i would want to get the tubular a-arms too. But im happy with what i got. Saves some money
Old Jan 24, 2011 | 10:03 AM
  #111
Engine: gone
Transmission: gone
Axle/Gears: gone
It'll look good anyway. You do great work. Im always impressed.
Old Jan 24, 2011 | 10:44 AM
  #112
Copchaser's Avatar
Aahhhh... now I see.
Old Jan 24, 2011 | 01:27 PM
  #113
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
you can use stock control arms on a tubular k member.
Old Jan 24, 2011 | 07:27 PM
  #114
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Thanks Anthony.
Travis, if something goes wrong with my stock setup or if i come across some extra money. That is something im going to look into.
Old Jan 29, 2011 | 12:19 AM
  #115
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Here is a little update. I was able to identify all the A/C wiring. Found some errors i did when i first did the LS1 install. All fixed now. Got to head over to pick and pull to find some connectors and brake line. Might go tomorrow. I test fitted the A/C air box. Fits perfect. I need to modify the wire harness but i got a good idea on how im going to do it. Its all going pretty smooth but i know im going to run into some fitment problems once i get the engine ready to install. Also i replaced the oil pan gasket. While it was off i was able to see the cylinder walls and man!! they look perfect. So does the valve train. Very clean. Im pleased with my oil changes
Here are some progress pics. Still need to finish up the air box and paint.
Old Jan 29, 2011 | 12:27 AM
  #116
Engine: gone
Transmission: gone
Axle/Gears: gone
Well if you cant find the connector your looking for I have two big boxes of connectors at the shop you can dig through! let me know!
Old Jan 29, 2011 | 12:33 AM
  #117
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Shoot i sure will. Thanks brada!
Old Feb 5, 2011 | 08:00 PM
  #118
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
So the wiring is almost done. I needed to put the motor back in with the L/T headers to see where the harness would be and what not. But its coming along pretty sweet. The engine fits with the modified A/C box. Still need some trimming for the coil packs. Nothing a dremel cant handle. So far so good:
Old Feb 5, 2011 | 08:27 PM
  #119
Copchaser's Avatar
Thats a tight a$$ fit kiddo! Looking good though, nice work. Did you paint the engine bay while motor was out or just cleaned it up a bit?
Old Feb 6, 2011 | 02:08 AM
  #120
Engine: gone
Transmission: gone
Axle/Gears: gone
yeah that is a tight fit but looks good. I dont think he painted it
Old Feb 6, 2011 | 09:17 AM
  #121
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Its a really close fit. No i didnt paint it. I did that when i first put the motor in back 4 years ago. Just never washed it since lol
Old Feb 6, 2011 | 11:47 AM
  #122
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
make sure to account for engine torque.
Old Feb 6, 2011 | 07:39 PM
  #123
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
No need to worry bro, going solid motor mounts
Old Feb 6, 2011 | 08:18 PM
  #124
Engine: gone
Transmission: gone
Axle/Gears: gone
solid mounts eh? Keep the tranny mount rubber!
Old Feb 6, 2011 | 09:51 PM
  #125
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
you better believe it yo! I was going to play around with the poly and rubber. we will see whats best
Old Feb 6, 2011 | 10:13 PM
  #126
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
solid mounts huh, after all this work to be comfortable in your ride.. hmmm.... my poly mounts give my iroc one hell of an idle.
Old Feb 6, 2011 | 10:17 PM
  #127
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
From what i read on LS1 tech. Its not bad at all, but then again they have a newer car. But i figure after all the upgrades ive done it should be the same. I dont have a crazy cam. But we will see. Test run, then if i dont like it, go back to rubber cause ive heard bad stories about fitting a poly on a LSx block
Old Feb 6, 2011 | 10:22 PM
  #128
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
true. your cam isnt as radical as mine, so it should perform as timid at idle as a ls1 saturn
Old Feb 7, 2011 | 12:14 AM
  #129
Engine: gone
Transmission: gone
Axle/Gears: gone
haha you guys. Solid mounts are pretty rough. But try it if you dont like it change it!
Old Feb 14, 2011 | 10:21 AM
  #130
86firebirdta's Avatar
Car: 1983, 1986, 2001 Trans Am
Engine: 305 cfi, 350 carb, LS1
Transmission: 700,Edge 2800 th350,Edge 3400 4L60E
Axle/Gears: 9 Bolt 3.27 Borg-Warner, built 3.73
Old Feb 14, 2011 | 10:23 AM
  #131
Got The Motor Pulled Out Of The Trans Am On Sunday Thanks To Some Help Of A Couple Buddies And Undercovertbi Got It Out Only A Couple Hours.
Old Feb 14, 2011 | 10:30 AM
  #132
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Cool TIM!! Looks like you should be having her running in no time.
Old Feb 14, 2011 | 01:21 PM
  #133
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
get to work on that lt1 swap!
good job guys, tim!
Old Feb 14, 2011 | 02:11 PM
  #134
lol i am... was at the meet with undercovertbi.
Old Feb 14, 2011 | 04:24 PM
  #135
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
oh i got confused.
Old Feb 14, 2011 | 06:36 PM
  #136
Copchaser's Avatar
Nice work guys.. Tim that spoiler is looking pretty nice on the hatch. Sleep with one eye open..haha
Old Feb 14, 2011 | 08:55 PM
  #137
Engine: gone
Transmission: gone
Axle/Gears: gone
yup nothing like a pulling a motor on a sunday afternoon...especially when it wont turn over and you gotta pull the torque converter with it caus you cant get flexplate bolts.
Oh so fun. Haha. I was mainly playing shop foreman and step in when they encountered problems! haha.
The wing is looking good for sure. Needs to do finishing work to it, but will look great when all done.
Old Feb 14, 2011 | 08:58 PM
  #138
Engine: gone
Transmission: gone
Axle/Gears: gone
oh i got confused.
Yeah not Vaugh. Tim!
He went up there with me!
When its your first time meeting people, its easy to get confused. No biggie. I think that was our first time meeting too. Im easy though caus im the fat guy. Then your like ooooh ya!
Last edited by UnderCover89TBI; Feb 14, 2011 at 08:58 PM. Reason: screwed up. doh.
Old Feb 23, 2011 | 07:45 AM
  #139
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Joey...now I know why I never saw your thread! Its in the NorCal section!
Car is looking good! Nice work on the A/C box. Kept it pretty close to mine...and you might have sealed yours up better. A word of advice... Line the inside of the box with some foil and foil tape...or any good insulation. Mostly the side near the headers. It droped my A/C temps quite a bit. Also...getting T-top shades helped a ton too. Even dark tinted glass was letting the inside heat up. For your drier...you can use a stock 4th gen bracket to mount that if you have one or have acess to one. It will bolt right to the chassis and hold the drier nicely.
Im not sure Ide worry too much about solid mounts. The LS1 has a revised firing order partially to help with vibes..amoungst other things. They run pretty smooth, even with bigger cams. Mine is on poly mounts though, and it doesnt move much at all. I watched it while it was on the dyno to see if it torqued much...and it hardly moved. Poly on both motor mounts as well as trans mount. The only issue I had was with oil pan clearnace. Because it was like...non-existent haha. I could hardly get cardboard between the pan and k-member. Like...heavy paper, not box type cardboard. So I notched for that as well, and I suggest you notch if you need to before getting it all back together. Try to mock it up with the trans and all once before your final install.
Keep up the good work!
J.
Old Feb 23, 2011 | 08:56 AM
  #140
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
J.
Thanks J. I was reading your old post and noticed that you lined the inside with tape. Thats a really good idea. I was going to use some DEI stuff on the outside too. Want to make it as cool as possible. The solid motor mounts are already in. My dad think its going to be a big problem with the #8 coil pack. I dont think it will.
I will upload some more progress pics later today or tomorrow.
Old Feb 23, 2011 | 10:40 AM
  #141
Car: 86 Trans AM
Yeah I used some foil tape and some insulation type foam with a sticky back. I tried several variations... Just go to lowes or home depot and check what they have. Here's what it looks like.
That outer most layer is fiberglass reinforced wrap with a sticky side and aluminum foil on the other. I think I got it from PACE or Summit or something.
Does your dad think #8 will hit during acceleration or something? I mean...with solids you wont be hitting much of anything. I fyou just move it slightly like I said it will be PLENTY fine. You wouldnt have to move it as much as I did...since I was just using what I had laying around as opposed to making my own piece. And also because Im not running solids.
Here is a HORRIBLE zoom in on the only picture I found that shows the coil.
You can JUST make out that the boot on the coil is up, just about level with the split in the HVAC box for the lid.
Dont forget...since its mounted at an angle, as it moves up, its moving over too. So it doesnt take much.
J.
Old Mar 9, 2011 | 10:51 AM
  #142
Engine: gone
Transmission: gone
Axle/Gears: gone
Well is thecar going to be ready for April 2nd at wills? Lack of updatesbro!
Old Mar 9, 2011 | 06:49 PM
  #143
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Im trying to use that date as a goal to get her done. Just been super busy at work and home. Have not worked on the car for almost month. Im going to do things different for the air intake setup for now. try to get an update this weekend
Old Mar 9, 2011 | 09:08 PM
  #144
Engine: gone
Transmission: gone
Axle/Gears: gone
alright. I was more teasing. Not trying to bust your ***** about it. haha.
Old Mar 12, 2011 | 08:01 PM
  #145
Copchaser's Avatar
WTH..... waitin for an update here I know u been busy kiddo. Hope all is well
Old Mar 12, 2011 | 09:08 PM
  #146
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
HAHAH Ive been neglecting my yard lol. Did some work on it today. No camaro time yet. Im hoping tomorrow Big John. I need to get her done already. Im sad, its been some really nice days to ride dirty
Old Mar 12, 2011 | 09:16 PM
  #147
Copchaser's Avatar
Your tellin me buddy boy... Hopefully I can start turning some wrenches in the next couple weeks. I wanna be ready to ride gangsta style by mid April.. haha
Old Mar 13, 2011 | 12:40 PM
  #148
Engine: gone
Transmission: gone
Axle/Gears: gone
ridin dirty and ridin gangsta style? im riding oakey style
Old Mar 13, 2011 | 05:51 PM
  #149
Copchaser's Avatar
Old Mar 13, 2011 | 10:45 PM
  #150
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
hahah only you Anthony!
