Nothing to do today, so I ended up in the garage...
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
I decided to "carve" a little bit on the manifold for my 57' , it's an Accel base that is going on my Trick Flow heads with a FelPro 1206 port. I am aware that the shaping isn't perfect, but it's good enough. The TPI is going to be temporary on the new motor, I am either going with a Holley stealth ram or do a manifold conversion on my Brodix HV1.
I had this manifold TIG welded to add the necessary material, then milled. I hope it works well.
Jason
Jason
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Nothing to do today, so I ended up in the garage...
Hey boredom leads to great things
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Jason, good to see you posting and working on those rides! I'll be in Monterey for Race N Rods on The 9th of July, would be nice to check out that blue Z in person! Let me know if you can swing on through.
Will
Will
Car: 91' Camaro
Engine: 383 ci
One of these years I'll make it up there for the show. I plan to head up to marina a good deal to run the autocross, how far are you from there ?
Jason
No idea
hectre13
Dec 11, 2023 08:14 AM
novaderrik
Aug 10, 2015 12:44 PM
