Northern California Discussion board for Northern and Central California.
Need Help with Gauge pod wiring
Old May 30, 2012 | 12:19 PM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
I'm installing the Two gauge pod with Electric Oil and Electric Fuel Gauges.
For those that have already done this, can you share what you found to be the best/simplest way to get the wiring together from the back of the AUTO METER/PRO COMP Gauge down the A-Pillar?
Where did you run the wires exactly? Was the pre-made Autometer harnesses long enough or did you have to elongate them?
I was thinking that the fuel pressure unit could hook up to the spot where the 9th injector used to plug in on the driver's rear corner of the fuel rail.
*I couldn't find any descriptions on SEARCH that actually described where Gauge Pod owners were running their wiring through.
Thanks, Nitro-Nicky
Old May 30, 2012 | 01:45 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Need Help with Gauge pod wiring
I ran the wire down the side of the dash with wire loom on it. tucked between the side of the dash panel and the jam trim. looks okay to me. but im also not a overly picky person. lol. i havnt actually put the pod in yet. the gauge is sitting on my dash. looks ghetto. I have the pod and will install it within the next couple weeks.
Old May 31, 2012 | 02:13 AM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
Mine goes down the pod behind the dash and through the firewall. looks messy but you really cant see it unless your looking for it.
Also not sure how big the Autometer sending units are, but the one that came with my B&M gauge is pretty big. It wouldnt look clean up y the fuel rail. I bought some fittings to install it inline at the frame rail.
Old May 31, 2012 | 09:46 PM
neagan's Avatar
Thanks; that's really helpful. Why drill more holes than we have to. With the T-Top cars there's already so much flex I'm afraid one of these days I'll drill a hole and the dang car will fold up like a taco on the next tight corner in the road! Nitro
Old Jun 1, 2012 | 12:21 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
Nitro is your car road worthy? going to make it to the santa cruz cruise???
Old Jun 1, 2012 | 03:22 PM
neagan's Avatar
It's got a low rod knock that electronic sensor pics up and throws the timing all over the place. I've had a new engine for two years but got sidetracked a year ago with buying and fixing up a major house renovation.
I just restarted working on it again on Saturdays. I've managed to put together several thousand dollars worth of parts that all need to be installed at the same time as the new engine. I guess I got carried away!
I wish I could go It's going to be that much sweeter when I turn the key over for the very first time!!! (probably next Spring)
Hey, thanks for asking! Nitro
Frozer!!!
Jan 19, 2024 04:55 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Jk_Under
Aug 17, 2015 03:08 PM
arod231
Aug 16, 2015 02:51 PM
89lsc
Aug 14, 2015 04:58 PM
