help with parts!!! Thx
Car: 89 CHEVY IROC-Z28
Engine: 355 Built/High Performance
Transmission: 700R4 Swap For T56
Axle/Gears: 3.73 Posi
whats a good 6 qt aftermarket oil pan for 89 iroc and under header spark plug wires? And good glass hid headlight housings? Id appreciate any info thanks.
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: help with parts!!! Thx
I buy wires that you have to cut yourself to the length you need. And I run 90* boots.
If your car is lowered a deeper sump is not ideal IMO.
If its stock depth but kicks out sidewise I'd say it is okay. But a 5 qt pan is suffice with a stock oil pump. If your using a high volume pump it could suck the pan dry at high rpm's. IMO you can spend your money in better places.
I dont know anything about the HIDs. Sorry.
LT1Formula
20
Nov 14, 2015 12:02 AM
