Northern California Discussion board for Northern and Central California.
Slow Acceleration
Old 11-20-2017, 02:00 PM
Transamrod85's Avatar
Slow Acceleration
Car doesn’t pick up quickly when I step on the gas, what can it be? New to any type for work around the car.
Old 12-01-2017, 03:36 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Re: Slow Acceleration
Originally Posted by Transamrod85
...what can it be?
With your extensive knowledge and description of your problem here, I'd say anything is possible. Some people think VTEC motors have a lot of "pick up", some don't.
Welcome to thirdgen ownership!
Old 12-01-2017, 10:56 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
So what kind of car do you have?
What engine is in it?
What transmission is in it?
Any history?
Modifications?
Old 12-01-2017, 04:04 PM
No mods, 305 small block automatic transmission with 67,000 miles
Old 12-01-2017, 04:09 PM
midias's Avatar
Neat is it carbureted if so high output not high output is it TBI is it TPI? Is it in a Camaro is it in a Firebird how about a Corvette maybe a Monte Carlo? Does it seem engine related does it seem transmission related? Has it always done this, did it just start doing it recently did anything else happen when it started doing this?
Please try to add information to your post that might pertain to the problem so we can have a better understanding of what is going on
Old 12-02-2017, 04:30 PM
The last thing I did to it was get the carb rebuilt, it’s a quadrajet carburetor, so maybe that’s what it is? Could it be a timing issue?
Old 12-03-2017, 07:45 AM
midias's Avatar
Did did you take out the distributor at any point? If not then your timing should not have been moved. Check all the vacuum lines and connectors make sure they are correct it all plugged in. If they messed up the carburetor rebuild it could cause all sorts of weird things
