ANY KANSAS PEOPLE!
#105
Car: '85 Firebird Sport Coupe.
Engine: Carb 350 4bolt.
Transmission: 700R4 Auto.
Re: ANY KANSAS PEOPLE!
RE: Any Kansas People!
>'85 Firebird Sport Coupe from Lewis KANSAS. Pulled bird off road to swap L4 to V8. Had a hard time removing that first bolt! Got engine and trans bolted in place though. Have'nt had much garage time latley. I would like to get togather with other 3gen's sometime. Any information on Kansas gatherings, let me know.
NOTE: Anyone outthere installed "RAM cast iron exhaust manifolds" on a 3gen with 350 auto?
terrypowers@yahoo.com
www.Powersville.net
www.Powersville.net
#106
Hi Terry,
I installed 1967 Camaro Ram's Horn style exhaust manifolds on my sons '86 Z/28 because i put an "old style, drivers side dipstick" block (350 - 5 speed) into it. Actually, I only put the drivers side on, but it bolted up and fit real nice, had to take it to the muffler shop to have them patch in the head pipe, but it works fine. I don't know if the old Camaro's are the same as what you have but it is what I had layin' around and after measuring to make sure, it worked out. Thought I'd chime in on your question. Marty
#107
Im in Independence, in the SE corner. Marty
#108
Car: 92RS
Engine: LS 402 inwork
Transmission: TH350
Axle/Gears: 10 bolt,3:73's
Once i get my cam replaced, i'd love to have a third gen meeting in Wichita sometime before the weather goes cold.
#109
Hi! I'm in Gardner, KS... About 16 mi. south of Overland Park. My White '82 Berlinetta Has a '70 Vette L48 350. I still have original LG4 with 59,000 mi on it if I want to go back to original...
#110
Car: 1987 IROC & 1968 Nova
Engine: 5.0 TPI & 350
Transmission: 700R4 & powerglide
#113
I'm in Salina... The ksfba.org forum is nearly worthless. It's mostly a bunch of LS1 loudmouth nonsense. It's very poorly moderated, so it's usually just unregulated trash talk. The technical content is very slim, and I haven't seen anything in the classifieds worth having in the last 3 years.
It'd seem there are more then enough members on here from Kansas to justify a 82-92 specific forum, if people were to participate. The regional forums on here are just about useless too... As if someone in Utah is local to someone in North Dakota. Someone should just make a KS 82-92 Fbody specific forum.
#115
Car: 84 frankenstein Z28
I have to admit when I first heard about ksfba.org about a year or so ago I was excited that there was such a forum. But overall, I wasn't impressed.
#116
JamesC
#117
Actually, I was thinking yesterday after I posted that "JamesC has posted some good thirdgen parts in the classifieds"... I'm glad that slip didn't offend.
So what are we going to do? Do we just try to participate on KSFBA until there's some 82-92 activity? http://ksfba.org/forums/showthread.php?t=3768 is a start... Or do we set up a new message board on a free host?
I'd do a lot more with my Firebird if there was a decent forum. I've been working towards getting the car drivable again recently and I'm basically there, just have to jump through the legal loop holes.
#119
It's not too surprising... I listed a storage unit full of stuff and had a couple nibbles, but mostly just wasted my time. I've had better luck selling stuff on Craigslist. I've still got an attic full of parts, and some stuff in storage that I'd like to get rid of, but out of sight out of mind, and there really isn't anywhere to post it.
#120
yea i understand. I am selling some stuff off the firebird. Just a little here and there. Its not hurting just sitting there. And got enough money to get the clutch i need for my conversion for my camaro. I tell ya what I will see what I can do on my end on the ksfba.org with the thread i made if no luck then i will use my rusty website skills and get on in the makings.
#122
Okay after hours later. I got a forum site up.
http://kansastgo.49.forumer.com/index.php
Hope you like. I know the url isn't what i wanted but eh. For starters not to bad. Check it out. All kansas peeps.
#123
Already registered and posting... Needs more traffic, but that'll come as more people find there way in.
You might want to go back to the first post in this thread and edit it to add the link, since people stumbling on this thread will probably start there.
#125
I am talking a gta body to the crapper tomarrow. let me know if you need any sheet metal 785-844-1475 Thanks Kevin hllahlavl@yahoo.com
#129
Thanks "Topless87" for the reply. I sence found a spec sheet on the manifold dimensions. Found that the header pipe would be two close to crossmember for my preferance. I think it could be done though. I'm not wonting to modify things that much. I went with my stock cast manifolds for a good fit. I'll consentrate on the rest of the exhaust system for maximun flow.
#131
The #1 thing http://kansastgo.49.forumer.com/index.php needs is more activity. The forum is there, it works 90% of the time and several people read it, there just aren't a bunch of people posting. Everyone just needs to register and start using it.
#139
I am parting out an 87 gta dark red with red interior. 350 tpi in tor down everything is there, it has a 93 up 10 bolt rear with alum disc Let me know what you need. I have the title if some one wants a roller, or if some one want the whole thing let me know Thanks Kevin 785-844-1475 or shot me a e-mail amd i will send pictures
#142
You account is in good standing, have you tried clearing your cookies? There's a link just below the forum list that lets you delete cookies sent by the forum.
I changed the log in attempt setting so you can enter the wrong password many times before it will lock you out. Remember the software is set to require a password 6-10 characters long, and it must contain letters and numbers. That threw me off cause usually I don't use numbers in my passwords.
#146
Reminder about Set'Em Up Jacks cruise-in Saturday (every first Sat. through Oct. IIRC) in Lawerence (1800 E. 23rd St. Lawrence, KS 66046). There are usually some cool cars in attendance. No cost. Sign in and you'll get a coupon for 33% off food in the restaurant--which serves darned good burgers and good cold brews.
Be there or be square!
JamesC
JamesC
#147
Car: 1991 Z28 camaro and a 1968 mustang
Engine: L98 350
Axle/Gears: Gm 10 bolt, 3:27 gears, G92 package
Topeka, Kansas here, 1991 Z28 J65 and G92
#148
Should anyone be interested:
Its Time for our third Dyno Day!! It will be on Sunday May 2nd At 12pm at Overkill Performance , it is on 23rd st off of Haskell in the shopping center in lawrence Kansas, $40 for three pulls FWD RWD welcome sorry AWD's also there will be a grill out so bring your own meat and eat
Hope to see most of you out there either to run or watch.
JamesC
JamesC
