Failed Emissions again
Car: 91firebird, 2000 camaro
Engine: 305 tbi,K&N, edelbrock intake & 3.8
Failed emission agaiN!! i have the worst time with that crap!! High Hydrocarbs and Carbon monixide!! I have to take to it a shop cant figure it out! Well the Bird will get fixed this week for sure, but not til Wednesday and plates expire the 15th (tuesday) but i get to use the flaming Astro for a few days!! O It is FORSALE if any one wants it $800 Obo (will trade for Just about any FBody)
Car: 88 Trans-Am 305 TPI, Yokahama dbs s2 front/ avs ES100 rear, Shift kit, K&N, complete 4th gen rear end, sun roof, 80's pinstripping, 4 point harnesses, memphis car audio
hey, i painted that beutiful van!!!
Well i getting the bird back tommorrow. Turns out a wire for the mass air flow sensor was bad. So the car thought it was running lean and was gettin to much gas for the catylic converter and it was all messed up.. but now it is fixed and no more VAn
R.I.P.
R.I.P.
Well got the car back took it to the emission place then their was antifreeze dripping and i popped the hood and the gasket between the mainifold and head was it where it was coming from so now i gotta get a new mainfold gasket and do that this weekend before i can start drivin it again.
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
haha
I'm laughing with you, my GTA had 17k on it when I bought it ans the damned intake was leaking. Got another 30k out of it by retorqueing it.
I'm replacing it this spring when i do the valve stem seals and springs.
later
Jeremy
later
Jeremy
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Emmisions suck
I hate the emmisions people. Simple as that. They serve no purpose. I found the easy way to pass was to just buy a new cat and have no leaks and you pass. Or sell the car to a family member like your wife and in Illinois that buys you another year and a half.
another trick to pass those smog freaks.....try squirting water into the air intake.sounds strange,right? it loosens up all the carbon in the cylinders....excess carbon deposits=higher compression=failed smog tests. just make sure the engine is running!!(and DONT let it die) it works especially well on older,high milage cars.
well got the car together today after on sunday the rvt in the back didnt hold and had to do it all again. And timing was hard too do. but why it didnt pass emissions was a bad air flow sensor wire. So the engine thought it was running lean so sent more gas and messed up the cat and it should pass now. I Hope
yes, horray for you indeed
i never noticed this before, but is the interior in the van pink??
Car: 92 firebird
Engine: 3.1
Transmission: 5spd
i feel ur pain
dont worry i have this till my bird is fixedand i havent even gone to emissions yet
<center>
<img src="http://i2.photobucket.com/albums/y41/shrop/Picture074.jpg" alt="Image hosted by Photobucket.com"><br><br>
</center>
<center><img src="http://i2.photobucket.com/albums/y41/shrop/Picture074.jpg" alt="Image hosted by Photobucket.com"><br><br>
</center>
i've never seen a chrysler van look so mean
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
