NW Indiana and South Chicago Suburb Looking for club members to have gatherings, cruises, and to help each other out.
How much fluid is used........?????
Old Apr 26, 2005 | 07:26 PM
Franchise's Avatar
Hey guys,
How much anti-freeze does a stock V8 GTA Radiator need for the entire cooling system?
How much Trans fluid does a 700R4 need?
Thanks for the help... I have gotten conflicting viewpoints.
Franchise
Old Apr 26, 2005 | 10:09 PM
Franchise's Avatar
Could somebody please check their owner's manual?
I need to know this since I am replacing it.
Thanks,
Franchise
Old Apr 26, 2005 | 10:54 PM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
The stock radiator needs as much as it'll take. Just 50/50 the antifreeze with water if you drive the car year round. Otherwise, 70 (water)/30 (antifreeze) it.
[edit] Also, don't just fill up the radiator and put the cap on if you had the hoses disconnected. Keep the cap off and keep topping it off until it's full. You'll have to watch it to be sure. Worst case scenario, use a gallon of 50/50, then use water, and test the antifreeze before winter to be sure it's strong enough.
I'd say to just run water, but then you're scrambling on the first cold night of the winter to drain the water and put antifreeze in so you don't crack the block... ask me how I know. lol
Old Apr 27, 2005 | 12:15 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Get 2 gallons of straight antifreeze and mix it 50/50 with water.
Should leave you a little bit left if everythign was dry.
later
Jeremy
Old Apr 27, 2005 | 08:11 AM
Franchise's Avatar
Thanks guys...
so 4-5 gallons of coolant (mixed)
and
???? quarts of Trans Fluid for 700R4??
Thanks,
Franchise
Old Apr 27, 2005 | 09:49 AM
3.8TransAM's Avatar
trans figure roughly 12 qts, , maybe a little more, maybe a little less.
later
Jeremy
Old Apr 27, 2005 | 09:13 PM
Franchise's Avatar
Thanks guys for your help.
Franchise
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
mfp189
Sep 27, 2015 09:25 AM
HikoriYami
Sep 21, 2015 07:11 PM
