two questions....
Car: 1994 Jeep Wrangler
two questions....
I was wondering.... how much it would cost me to switch to Speed density. Also If i were to do it, could somebody lend me hand? I am hopping that it doesnt come to this, but if mid/ late april rolls along and I still dont have this stuff worked out w/ the 165 ecm... i am just gona say fu*ck it!
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
come join the club.. im going from 305tbi to 350 tpi speed density this spring once i get everything together.. depending on when your going to do it.. i try and give you a hand... besides i could user the knoledge for when i start my project... you gonna swap the harness ??
well, I would prefer not to have to get a whole new harness(tight on $$$), but it seems that if i am having a hard time switching between maf computers, that butchering the harness i have now further isnt going to help matters at all.
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
Let me know. I completely rewired a speed density system, granted it was with a Painless harness (easiest way) but I have done it and would be more than willing to lend a hand
harnesses are not cheap, but if you spend the money it makes it easier with a new one....they are around like $350-400 i think
Car: 91 RS
hey 91CamaroRS305. i might need your help when i get around to it.. i have a pretty clean speed density harness form a 92 but im sure how to wire things so people who have doen it would help me as well..
also not sure if you could get a MAF harness to work with speed denisty.. someone will know if ther is a conversion kit or something... also if you need to look at a speed desity harness i have one right now in a box..
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
this is tim and dean....
Mike, let us help you, we have both done it with 100% success. I would hate to see you get help from someone who does not know. Re-pinning the harness and such is not as bad as it may seem.
Catch me on aim.
Later
Catch me on aim.
Later
Moderator/TGO Supporter
Car: 1997 Z28
"also not sure if you could get a MAF harness to work with speed denisty.. someone will know if ther is a conversion kit or something... also if you need to look at a speed desity harness i have one right now in a box.."
Conversion kits are very big pieces of crap, ask curtis......
A MAF harness can be re-pinned to work with SD very very easily.
this is true, but you need the connector pick set to take the connectors apart and fit the new wires in
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Easy as heck to do.
Once u go from stone age 85 to 86-89 maf its another hr or two to go to SD.
From there u can switch easily to the 749 for boost :-)
Work slowly and mark everything first and write out exactly what your doing.
later
Jeremy
later
Jeremy
Originally Posted by 3.8TransAM
Easy as heck to do.
From there u can switch easily to the 759 for boost :-)
later
Jeremy
later
Jeremy
Car: 1997 Corvette
All I had to buy to convert over was a MAP sensor and connector (I should have an extra Mike), 730 ECM with pigtails (can get the MAP/ECM connectors cheap off of tpiparts.net). Used my stock MAF knock sensor and a resistor instead of buying a new $40 knock sensor.
You will need to either convert to an electronic VSS (might also have a spare one of these...assuming the one in my car is okay) or get one of those adapter boxes to convert your cable to electronic signal for your ECM.
I know there is extra work required if you have an '85 ECM. I'll get you the info on it later.
I have an extra MAF and relays if you need those too :P
Last edited by DuronClocker; Mar 23, 2006 at 03:07 PM. Reason: Automerged Doublepost
lol
Junkyard is cheap :-)
Rob a TBI app of the map sensor and harness.
Snag a 730 from a SD front driver. Get a v8 305 manual memcal.
run the resistor for the knock like he said. Might have to swap sensor since u got a 85, not sure on that.
Shouldnt have to convert anything for the vss, the camaro used a cable until 92? The firebirds switched to the electronic sensor in 86 or 87. So double check the wiring for them.
later
Jeremy
later
Jeremy
Car: 1997 Corvette
lol
later
Jeremy
later
Jeremy
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
camaros switched to VSS in 90. this is considering the mechanical cable clusters were in cars from 82-89.
