NW Indiana and South Chicago Suburb Looking for club members to have gatherings, cruises, and to help each other out.
Some Questions.....
Old Jun 21, 2006 | 02:11 PM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
Some Questions.....
Well, the SD harness deal fell thru, so i am switching to an 87' harness. Yes, i gave up on the 85 harness. Anyways, I am having some issues w/ the distributor. The 85 is an in cap distributer, and the 87 is a remote coil. I was just wonderin what kind of adapters there are so i can use my 85' distributer. Another option is using the 87' distrbuter, but its in sort of sad shape and i would rather use the 85' if its viable.
Old Jun 23, 2006 | 07:53 AM
mean57's Avatar
Car: 87 gta
well. i'm in a good mood right now and happen to have a spare dizzy from the parted 88 formie in the garage. if you wan't it it's free come and get it.
i'm not very far from you. oh yeah you have a p.m.
Old Jun 23, 2006 | 10:35 AM
thanks for the offer, but i already swapped connectors between harnesses. the 85 dizzy should work now. My fuel pump issues are what are really frusterating me right now.
Old Jun 23, 2006 | 10:47 AM
wrightz28's Avatar
Car: '88 GTA,'85 z28
Engine: L98, LB9
Transmission: 700 r4
Axle/Gears: sleepy 3.23, hello 3.73
Hmm, another '85 with f/p issues? What's yours doing if i may ask?
Old Jun 23, 2006 | 03:27 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Fuel pump is powered by the fuel pump relay and also has a backup system routed thru the oil pressure sensor.
If the relay is bad and you crank until I believe 4-6psi oil pressure it will fire the pump up.
Wiring issues here can cause issues and vice versa
later
Jeremy
Old Jun 24, 2006 | 11:11 AM
actually.... I finally figured out what the problem was and it is sickening! I did not know there was a god damn fuse for the fuel pump near the battery! Anyways, that fuse was blown this whole time. I missed 3rd gen fest and have not been driving my damn car all this time because of a little 20 amp fuse!
Old Jun 24, 2006 | 12:08 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i've never seen a fuse for the fuel pump near the battery it's always been in the fuse block.
Old Jun 24, 2006 | 05:02 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
I know what you mean, that's the stupidest placement idea I've ever seen. I thought i was crazy searching the fuse block for the FP fuse and finally found it in a weatherpack up there.
