Need some head work. Any recommend a good shop?
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Just need small work done. Mainly having thenn checked over, decked and new valve seals.
I have a pair of heads with Beehive springs for my lt1. The current heads on my lt1 are diff castings. The replacement head have bad valve seals mainly on cyl 2 and 4.
Anything else I should do to em before I bolt em on? Any good shops to have em done? What will all this run me?
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Need some head work. Any recommend a good shop?
a-team speed shop in tinley park, IL
only place I'd take them to IMO
Car: 1989 Trans Am GTA
Transmission: M28 T56
If you are going to go through the trouble of replacing the heads, get some mild port work done. Even a simple good valve job can net some nice gains.
not sure your time frame but high-flo heads out of alsip is the only place i'd go imho.........but to second the previous, dont just slap them on,almost not worth it. even a mild port or just a bowl blend and a casting cleanup with a good 3 to 5 angle valve job will reap bennies and not too much coin for the dollar.
backtothe80s
Sep 5, 2015 12:39 AM
rsrmoore
Aug 7, 2015 08:44 PM
