Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
advancing timing
Old May 30, 2002 | 08:45 AM
mustang1/4's Avatar
advancing timing
if i advance the timing on the distributor before i race, will this make my car run any quicker?
Old May 30, 2002 | 12:21 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
I'll be experimenting with this at the track on Friday, but I'll be retarding timing instead of advancing. I already trigger the knock sensor.
I've heard the general rule is to run as much advance as the engine needs, without detonation. This is what I'll be doing. I'll keep you updated.
Old May 31, 2002 | 07:01 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
When I had my lowly 305 in, we set the timing at 36 degrees fully advanced-anything higher and it pinged plus had a hard time turning over. Ran mid 15's. So we started backing it off mainly so it start easier and when set at 32 degrees fully advanced I ran 14.8-14.9 the rest of the day. Each motor will be different so just experiment on a test and tune day. I see too many people changing timing, jets, air pressure, etc. between rounds at the track during racing and 9 times out of 10 they go out the next round cause they have no idea what effect the new mods have produced so they're dial in's are way off. We've always tested at home or test and tunes, then never open the hood (except for cooling) on race day. Buddy gone to nationals twice and been second or third in points at our track at the end of the year for about 4 years running.
Old May 31, 2002 | 08:11 AM
mustang1/4's Avatar
ive noticed that i used to have a horrible hesitation and some studdering, but now if i mash the gas (auto trans) i can fry the tires!! now i will have traction probs. thanks guys
Amillionoh7
May 24, 2020 08:01 AM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
Thirim
Aug 9, 2015 06:19 PM
djmarch
Aug 9, 2015 05:27 PM
