what should i run?
what should i run?
all of my mods are in the sig. i ran a 14.12 with a 1.94 60' @97mph. since then i have added 176 fan switch, pipes in place of cats, and slp1 3/4" headers. does anyone think that i will break 13's now? if so by how much and what mph?
thanks,
David
p.s. i know this is a general and stupid question but all of my friends keep telling me that i will only pick up 1 or 2 tenths but mph will increase a good bit. so im hoping to settle it(at least until i run it again).
thanks,
David
Car: 88 IROC-Z/00 GTP/05 VUE Redline
Engine: LB9 305/3800 SC/3.5 SOHC V-TEC
Transmission: A4/A4/A5
You should be able to hit some 13.8's to 13.9's with that setup if you run under similar conditions.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You're close enough to the 13's that it's very possible you'll get a 13 second timeslip. I also agree that you'll gain more MPH than ET. I'd guess that you should get a 100 mph timeslip depending on the conditions.
Personally though, I think your headers are too big. You'd probably see more of an improvement with 1 5/8" headers.
well i took the header size into consideration and after alot of research on the board it seems as if the 1 5/8 would give me more bottom end or torque and the 1 3/4 would give me more top end or horsepower. i thought about it and realized that i already have torque out the @$$ so i decided to go with the 1 3/4.
thanks,
David
thanks,
David
eightsixseven
Dec 16, 2024 01:50 PM
Fast355
Dec 2, 2016 06:33 PM
