which slicks to use?
Car: 1984 Z28
Engine: 454
Transmission: Th400
I have a 115"wheelbase altered with a mild 468 BBC and a powerglide. I will be footbraking, torque converter is 3200-3800 10". The car has old hard 14x32x15 slicks on it. The rearend has 4.56 gears and weight of vehicle should be around 2000lbs. Should I put 14x33x15's on it or 14x32x15's and should I use stiff sidewalls or not? The cam is 236duration@.050" lift and it has .540" lift. 850 carb dual plane intake oval port heads and zoomie headers.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
If the vehicle is geared properly to cross the finish line at or near the red line then keep the same size tires.
That's a lot of gear for such a light vehicle. You shouldn't need stiff sidewall tires for it.
Car: 1984 Z28
Engine: 454
Transmission: Th400
slicks
I'll probably go with 14x32's but I noticed the goodyear 14x32's were stiff sidewall and I know they are mainly for heavier cars, but since I am not using a transbrake and not really making that much power, I was thinking I could still use them and get traction and have more stability at higher speeds. I have a sliderule that shows 6000rpm with 32" tires to be right at 125 mph, so I should be good in that respect.
