Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
nhra stuff
Old Mar 25, 2003 | 01:05 AM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
nhra stuff
I know, it's a pretty general topic, and i'm sure this is pretty biased toward steven 87 iroc and camaro85500...or whatever his name is. But where do you have your battery on/off switch at, do you have to have one if the batter is mounted in the front still?
Old Mar 25, 2003 | 10:37 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A rear master switch is required when the battery is not in the stock location. So if you keep the battery mounted up front, you don't need a rear master switch until you run 9.99 in the 1/4 mile.
Mine is mounted on the right side beside the license plate. There's enough room behind the cover for the wires. The cables then go through the body to the batteries.
Make sure you buy a rulebook whenever you need specific instructions on rules.
Old Mar 25, 2003 | 10:39 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Look at the picture in this link. https://www.thirdgen.org/techbb2/sho...hreadid=169008
My switch is mounted in the similar location.
Old Mar 25, 2003 | 11:31 PM
25THRSS's Avatar
where can you buy a rule book?
Old Mar 26, 2003 | 12:03 AM
Engine: V8
i'm wondering the same question
Old Mar 26, 2003 | 07:19 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Your local speed shop or track should have them. You can also buy them from Jegs and Summit. $10. You don't really need to buy a new one every year. The rules change slightly but only for the more specialized classes. The rules in ET brackets change very little. Usually when the oldest helmet requirement has expired etc.
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
anesthes
Sep 30, 2015 07:48 AM
