Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
What E.T. to expect?
Old Apr 25, 2003 | 07:09 PM
89 RS vortec 35's Avatar
I want to know what kind of E.T.s to expect with a 560hp 540lb ft 383, T10 4-speed, and 4.10 gears assuming no tire slippage or clutch slippage in a 3600 lb Camaro. Could I expect 11-12s?
Old Apr 25, 2003 | 07:32 PM
tommyboy's Avatar
Car: 87 Formula
Engine: 355
Transmission: TH400
Axle/Gears: 5.00
Do you have DSL or a Cable modem?
Old Apr 25, 2003 | 07:35 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Assuming that's engine hp and not rear wheel hp and there's no tire slippage, I'd guess really low 12's and possibly a high 11.
Go to a track and find out. That's the only way you'll know for sure. 600 hp won't run 12's if you can't get the power to the ground so a guess is just a guess.
Old Apr 25, 2003 | 09:48 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Old Apr 25, 2003 | 10:21 PM
25THRSS's Avatar
If that is rwhp then you could run 10's. If it is flywheel hp I would say 11's if you can hook.
ZZ3Astro
Aug 13, 2019 12:57 AM
86z89iroc
Oct 5, 2015 01:04 PM
hartsmike
Oct 2, 2015 07:11 AM
80smetalfan
Sep 22, 2015 02:55 PM
BWilcox
Sep 20, 2015 12:19 PM
