new best time with the vortec headed setup
Car: 1986 Z28
Engine: 355
Transmission: th400
Ran down atco last night.
Best time was an 11.960 @ 113.51
time slip like this
1.666---------------------60
4.924---------------------330
7.613 @ 90.68----------1/8
9.902----------------------990
11.960 @ 113.51-----1/4
finally getting my too tall slicks to hook well.
the motor's a vortec headed 355. 10.75 compression bowl work and a valve job on the heads. comp Xe 274 cam. 780 vac sec holley, 700r4 trans. ACT 3300 stall converter, and 3.73 gears with 28x10.5x15 mt etdrags./
Finally a run worth having the 8 point bar in there for.
time slip like this
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
Nice run for sure. That is a great 60ft time. What is your rpm at the top of the track? I am running 3.73's as well and have been thinking of going to a 28" tire.
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
N/A?
damn homie, what's the intake, rocker ratio, and specs on the pistons, rods and crank?
also, what's race weight and how much suspension work has been done?
sorry i'm quizzin you, thats the kinda times i'd like to be running
Car: Black '91 Z28
Engine: Bone Stock L98
awesome times man, you have just seeled the deal for me.. was thinking about the vortec's and now that i see the potential i am definetly going to get a set. I'm not gonna be anywhere near as fast as you for a while, but it's nice to see the vortecs can produce some good numbers with the right combo.
Dave
Dave
Car: 1986 Z28
Engine: 355
Transmission: th400
now i had a very long post written with just about everythign the car had...
But the board ate it..
and out of spite i'm not going to write that damn much again.
I'm crossing the line at about 5700 rpm. @ 113+
Intake is a performer rpm vortec intake with a 1" open spacer.
rockers are 1.5 crane race golds
pistons rods crank.
trw forged flattops, polished x rods, and an eagle 4130 crank. ballanced, block was align bored, and decked the pistons actually pop out of the bores .002
race weight i'm not sure of.. haven't wieghed it yet.. i'd say around 3400 if not a bit heavier with all the steel welded in it. aka the boxed lcas, panhard rod.. let alone the 8 point bar, and the sfcs, and the spohn torque arm
rear suspesnion has that stuff and adjustable rear shocks... and lakewood 90/10's... with no sway bar in the front... S10 manual box
NOT a full wieght car by any means.
the heads have bowl work, and a valve job on them. as well as a clean up deck
pistons rods crank.
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
damn dude you got that MF'er hookin..by your trap speed id day your makin "only" 375-400 ponies, but your putting it all down like now...good **** man
with the pistons poping out of the bores, you dont have any quench area..its kinda late now, but no doubt costing you efficiency and power
Car: 1989 Iroc Z L98
Car: 91 Z28
Engine: Forged 383
Transmission: Pro-built 700R4
Yes the ls-1s are underrated. My cousin's bone stock 98 A4 Ram Air put 285rwhp to the wheels. That's about 360fwhp. There are 01 and 02 stick cars that are putting 315-320rwhp. That's about 390fwhp. The stick cars on average put about 20 more hp to the wheels.
Pony Killer is probably putting out about 330rwhp and gobs of tq.
if u crossed the line at about 5700 rpm with 3.73 and 28 inch tires youd be goin 126 mph. my car crosses the line at about 5500 rpms @ 106 (26 inch tires 3.43).where did i go wrong with my math?
Car: 1986 Z28
Engine: 355
Transmission: th400
converter slip is what's wrong.. ther'es probalby a good 12-15% silp in the converter.
if i'd get off my lazy ***.. i'd hook the lockup to the converter
it's still running pretty good
Car: 88 Camaro
Engine: 355
Transmission: TH-350
Re: new best time with the vortec headed setup
time slip like this
time slip like this
NICE TIME!!!!!! Do you have any pics of your car? Because if you race at Atco I've had to see it cause I'm pretty local also.
Car: 88 Camaro
Engine: 355
Re: Re: new best time with the vortec headed setup
Car: 1986 Z28
Engine: 355
Transmission: th400
I'll have to dig the pictures up... but it's a "destinctive" looking car
it's a red 86 Z28
the left frond fender is black, the hood is black w/ a 4" riveted on cowl... also black.. right front fender is brown... the nose piece is mostly grey.. but the left front corner is like an urban camoflage... the front and right ground effect are red.
grey 15" Z28 rim in the front...
15" weld draglites in the back
i can garauntee there's not another one round here.
it's a red 86 Z28
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
