Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
New Best Time...
Old Oct 19, 2003 | 11:31 AM
Kwik88's Avatar
Car: 1988 IROC
Engine: 383 SP
Axle/Gears: Dana S60 4:10
New Best Time...
Out at U.S. 41 Sat. we had a head wind of about 20mph, still ran a new best with the camaro. 60.ft - 1.69
1/8 et - 7.636
1/8 mph - 90.41
1000' et - 9.988
1/4 et - 11.978
1/4 mph - 113.02
Will probably be getting it touch with ski for some prom changes soon. I think this combo has 11.5-11.6 in it, hopefully!!!
Old Oct 20, 2003 | 11:26 AM
MdFormula350's Avatar
what kinda specs does the camaro have?
those are some fast times, congrats.
Old Oct 20, 2003 | 11:36 AM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
Very nice run. Yes lets hear some details on your setup.
Old Oct 20, 2003 | 11:44 AM
TTA 1387's Avatar
Car: 89 20th Ann. TA
Engine: Turbo 3.8 V6
Transmission: 200 4R
Very nice
Old Oct 22, 2003 | 08:26 AM
Kwik88's Avatar
Car: 1988 IROC
Engine: 383 SP
Thanks guy. It's a 383, SR, 219, AFRs 190 (unported). I'm still using Edelbrocks TES headers. Not sure wether to use 1 5/8 or 1 3/4 headers. I see good points to each of them. We thought we had 12 psi in the tires sat. at the track, come to find out it was 17psi. Between that and a few other little things I think there's some more in it.
Gary
Old Oct 23, 2003 | 03:17 PM
camarojoe's Avatar
Car: 91 Z28
Engine: Forged 383
Transmission: Pro-built 700R4
Cool, there's yet another good running car with the TES to throw in the header debates. Good times. Are you planning on trying a different set of headers soon, Kwik? It would be cool to see a comparo, since so many run your combo.
Old Oct 24, 2003 | 08:39 AM
Kwik88's Avatar
Car: 1988 IROC
Engine: 383 SP
Thanks. Probably over the winter. Not sure how much of a change it'll make. Probably go with the 1 3/4.
Gary
Old Oct 24, 2003 | 01:43 PM
ski_dwn_it's Avatar
Engine: 2 mice and a cat
For what its worth...never knew there was drag race talk in there like this...cool....anyways you might want to dig up where Corky and I tested my 1 3/4" headers to his 1 5/8" headers on his 406 this season. They were changed in the pits, lol, after a few baseline runs. With DAs taken into account. the gain was about .06-.07 sec. Much less than I thought it would be also. But results are results. That is on a 406 in the extreme low 11s.
I would say spend the 400 beans elsewhere.
Old Oct 25, 2003 | 11:47 PM
camarojoe's Avatar
Car: 91 Z28
Engine: Forged 383
Bzzz...Misinformation here. Ski, I'm almost certain the 1 5/8's in that test were not even close to the cramped y-pipe, restricted collectors, or the restricted "in general" characteristics found in the Edelbrock Tes system for third gens. They probably weren't even shorties were they? If they were even similar to the edelbrocks, Ski, I apologize. But if you tested 1 5/8 long tubes to 1 3/4 long tubes, then I my point may have some validity.
Old Oct 26, 2003 | 01:11 AM
ski_dwn_it's Avatar
These were longtubes run wide open for the testing. Sorry. I didn't catch the TES the first time around. Anyways....its still some useful information to keep in your back pocket!
Old Oct 27, 2003 | 02:56 PM
Kwik88's Avatar
Car: 1988 IROC
Engine: 383 SP
Ski-
What's your thoughts on going from the TES to the longtubes on my setup?
Gary
Old Oct 27, 2003 | 03:16 PM
ski_dwn_it's Avatar
I can't say I have enough information from the TES to make an educated suggestion. Sorry..maybe someone else has done a comparison.
Old Oct 27, 2003 | 05:18 PM
David 91RS/Z28's Avatar
Originally posted by Kwik88
Ski-
Gary
Not the same header but a similar change I experienced. I swapped from SLP Tri-Y 1-5/8" headers to Hooker Long Tubes and picked up a solid 3 tenths and 2 mph. The torque on the low end was improved quite a bit. This is on a 355. Good luck!
luvofjah
Aftermarket Vendor Review
Aug 31, 2015 11:22 AM
ShaneBuss2
Carburetors
Aug 20, 2002 11:09 PM
nj88v6
Aug 14, 2002 12:21 PM
Kouldge
Aug 4, 2002 12:50 PM
Demon Z28
Pacific Northwest Region
25
Jul 1, 2001 02:07 PM
