Picking out a camshaft ..????
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
1992 Camaro RS
3340 race weight
355
World products sportsman II heads
weiand x-celerator single plane intake
edelbrock 750 CFM carb
bottom-end is more or less a stock rebuild - dont want to spin it past ~6000 RPMs
700R4 stock convertor - will be replaced by a proper stall speed when the cam is picked out...
3.73 rear gears
Ok, I think those are all the basics. Let me know if yall guys need any other information. I'm looking for a hydraulic flat tappet camshaft that will give me the best power curve. Because of my stockish bottem end I need power where I can use it (READ: no peak HP at 7500 RPMs type of thing)
Here are a few of the cams I am looking at:
230 Intake Duration
230 Exhaust Duration
.480" Intake Lift_______________Cam # 1
.480" Exhaust Lift
109 LSA
235 Intake Duration
235 Exhaust Duration
.507" Intake Lift______________Cam # 2
.507" Exhaust Lift
108 LSA
234 Intake Duration
244 Exhaust Duration
.488" Intake Lift_______________Cam # 3
.510" Exhaust Lift
114 LSA
222 Intake Duration
234 Exhaust Duration
.467" Intake Lift________________Cam # 4
.494" Exhaust Lift
230 Intake Duration
236 Exhaust Duration
.490" Intake Lift__________________Cam # 5
.490" Exhaust Lift
110 LSA
Cam #1 = Lunati Bracket Master II
Cam #2 = Lunati Street Master
Cam #3 = Crane "Blue Racer" (Summit Racing sells it also)
Cam #4 - Crane PowerMax
Cam #5 = Comp Cams XE274
I think that all of these cams would work pretty well and make decent power with the heads. All durations are at .050" lift and all lifts are with 1.5 ratio rockers (when I do go with roller rockers I will be using 1.6's).
Click here for the flow information on the Sportsman II heads.
Which camshaft would best meet my needs. This is a street/strip car with no AC, heater, defrost or any of that. So it's not like it needs to idle perfect and make lots of vacuum. The car is driven daily sometimes.... Needs to run on pump gas etc....
Thanks for the help in advance...
Brady
3340 race weight
355
3.73 rear gears
230 Intake Duration
.480" Exhaust Lift
109 LSA
235 Intake Duration
.507" Exhaust Lift
108 LSA
234 Intake Duration
.510" Exhaust Lift
114 LSA
222 Intake Duration
.494" Exhaust Lift
230 Intake Duration
.490" Exhaust Lift
110 LSA
Brady
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Picking out a camshaft ..????
Originally posted by brodyscamaro So it's not like it needs to idle perfect and make lots of vacuum. The car is driven daily sometimes....
[/B]
[/B]
Transmission: 4L80E/4L80E
Just from reading what you wanted to accomplish (before I read what cams you were looking at), I was thinking "XE274".
There is a lot more to cam operation than the specs you quoted. The advice you received on your post in the other forum has sound advice.
RedLeader289
May 28, 2019 01:47 PM
