Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
1/8 mile
Old Dec 18, 2003 | 11:44 AM
nc-iroc's Avatar
Car: 1989 Iroc-z
Engine: 1998 L31 350
Transmission: 700 R4
1/8 mile
I ran the 1/8 a few weeks ago. The only change was a new 3.27 gear in the 9 bolt. I had 2.77s. My best time was a 8.828 @ 79 mph with a 2.0 60 ft. The problem was the weather, 49 degrees meant no traction. All I had was street tires. I'm hoping to do a little better this spring. Just wondering how I look with the amount of mods I have listed below.
Old Dec 18, 2003 | 12:40 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Mph seems low. With a smaller cam and 9:1 compression my 350HO crate went 8.4 @ 85 in the 1/8th on street tires.
Old Dec 18, 2003 | 03:48 PM
nc-iroc's Avatar
Car: 1989 Iroc-z
Do you suppose that is because of your converter? I know my mph is slow, I think that is because of running the factory prom and rockers. I don't believe my motor has very much top end, which is pretty typical of TPI. Making changes to the prom and valvetrain, will probably net more HP. Thanks.
Old Dec 18, 2003 | 05:08 PM
I think the converter helped, but I wasnt taking full advantage of it at the track being on radials.
Old Dec 18, 2003 | 06:43 PM
muggsyjack's Avatar
Car: 1992 RS Camaro bracket car
Transmission: TH-350
Our 305 is running a best of 8.11 @ 85+ in 1/8th mile. We are using a big cam, 750 vac. secondary holley, 3200 stall converter, th-350 and 4.10 gears. Also producing 1.84 60' times with 28 X 10.5 X 15 slicks. Adding a dual plane a slightly milder cam to improve torque. This should drop 60' time a little.
Your MPH does seem low, we have never run slower than 81+ when running 8.80's.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
dbrochard
Oct 3, 2015 12:43 PM
Nick McCardle
Sep 10, 2015 08:36 PM
GouldyGTR
Sep 7, 2015 09:05 PM
tgp1990
Sep 4, 2015 06:24 AM
