What can I expect from this
Car: Transam
Engine: ZZ4,Holley Stealth Ram,Commander 950
This is the first time ive visited this board,so please go easy on me guys.
Im just replacing my 305TPI 700R4 1985 Transam drivetrain with ZZ4 plus hotcam from Sallee Chev(rated at 390bhp)with a complete Holley Stealth Ram set up complete with 950 commander and WB02.Nothing from the original TPI will be used.
My Auto is to be replaced with aftermarket T56 6 Speed.
The gear ratios are as follows;
Rear axle 3:27.1
Gearbox 1st 2.97 2nd 1.94 3rd 1.35 4th 1.00 5th.84 6th.62
My rear tires are 275/40xs18" so overall diameter is 26.66 ins and tire circumference is 83.75
Im not really interested in 1/4 mile racing I need a fast road car with low rev high speed cruising.
I would be very grateful if you could give some opinions and calculations.
Thanks to you all for reading this and I wish you a great 2004 from here in the UK
PM
Rear axle 3:27.1
PM
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Car: 1989 Trans Am GTA
Engine: 350 5.7 L98
Try This Link...
The guys here at this link can help you also www.fbody.com
Car: Transam
Yes,I too think the gears may be the wrong ratio but its what im stuck with at the moment.Next year however I will probably put in a complete new rear so i can alter the gears then
PM
PM
ZZ3Astro
Aug 13, 2019 12:57 AM
