Why do people say "no traction 2.0 60ft". that is SO annoying.
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
I'm just wondering....lately when people post times from their near stock or slightly modified thirdgens that run 13's or slower......they say "it ran a 14.XX @ XX mph, BUT, had a no traction 2.0 60ft". Am I the only one that finds this incredibly amusing for a 14 second car??? In Tucson, running a 2.0 60ft in any car 13's or slower is considered hooking EXTREMELY hard for street tires. When I ran a 13.5 in my girlfriends T/a, it had a Th350, 3,200 stall 10 inch converter, and M/T slicks....it pulled a 1.90 60 ft. That was with a vortec 350.
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
usually people aren't saying it about 18 second cars, i agree with you on the ones that do. but when you get down to 15's or 14's a 2.0 60 is a signal that traction is starting to suffer, you may not be coming off the line with the tires blazing, you might not hear any screeching or see any tire spin, but there is traction loss for the first 60' and the traction usually has a negative effect on your total et. Even if you only slip 1%, by the end of the 1/4, you've lost 13.2 feet, your tires moved enough to cover 1333.2ft, but your car only moved 1320ft. if you change from street radials to slicks, without changing anything else, you'll see how much you give up just through a very tiny amount of traction loss...atleast thats my belief.
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Re: Why do people say "no traction 2.0 60ft". that is SO annoying.
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
hmm ET STREETS and 1.72-1.76 all day long!!! J/K
I used to cut in the 2.0-2.1 range and the car seemed to hook very well. I think 2.0s are good 60s for a street tired 13-14 second car!
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Originally posted by tpivette89
on street tires i usually get mid 1.8 sec 60fts... so a 2.0 would suck a$$ for my car.
and yes im running in the 13s
Car: 87 Vette 85 TA 82 Z/28
Engine: 3 - 350's 388 400
Transmission: 2-700R4's 1 T56 Setup!
Axle/Gears: 2.59's 3.42's 3.73's
these kinds of posts always make me laugh!
"Man i spun so hard and ran only a 2.0 60' and ran a crappy 14.89 at 92 mph"
lmao
let me tell you something YOUR NOT SPINNING!
now put old GatorBacks on 16" iroc rims in a 13 second car at full pressure and launch it then you can say that.
1. buy a good street tire. not these pep boy specials
2. drop pressure
3. slightly heat them. spin them up real good but don't over do it unless your like me
4. learn how to launch
5. takes seat time to launch the car correctly
Jim if you'd like i'll show you how to launch that car of yours
come out to cecil this friday night
lmao
2. drop pressure
I have been to the track once last fall and my best 60' was 2.15. It was very traction limited even though the tire just barely spun. My first time on a track with a 5 spd and a 3.42 open rear end and that was as much power as the car could hook up that night. When I would try to give it just a little more off the line I was getting 2.4 - 2.6 second 60's. It just comes down to feeling what the car wants to do. Too many people just floor it off the line then blame traction for their bad times.
Car: 1989 Iroc Z L98
330 ft is just as important if not more important than the 60 ft for my car. If my car 2.0 60 foots it means it is spinning to the 330 ft, which is bad for me on radials.
Do you consider that hooking?
Bob
Engine: V8
Re: Re: Why do people say "no traction 2.0 60ft". that is SO annoying.
Originally posted by 88 IROC BOB
A 3200 stall and slicks and you only got a 1.90 60 ft??
Bob
Bob
Yeah, I would say so.
I tried a 2800 stall in my IROC a couple of years ago and got a few in the 1.7's.
With the stock stall and et streets it would hook good with 1.9's being normal.
Bob
Bob
Car: Junk
Bob
Bob
That because you live in Canado at some *** aweful track!! here in tucosn 2.0's are considered hooking hard!!
And a 2.0 60 ft is the same whether you come out spinning or you hook. Kind of depends on the power you're making.
Bob
Car: 05' GTO
Engine: 6.0L
Transmission: A4
mad-mic what do u have against pepboys tires? my brother is hookin in his 91 z28 withthe Futura ultra-z tires and with a worn out posi, he gettin between 2.1-2.04 for 60'' and his best so far is a 14.1 at 97 mph.
i got slicks on my car and for some stupid reason im only pullin a 2.32 and it pisses me off that its only gettin a 2.32 with slicks. my suspention isnt stock or whats left, its very stiff. that might play in a part why my times suck, and also my floorboards are rusted thru in 3 large spots. im using a used set of M&H roadmaster dot slicks that have about 20-25 runs on them and there just about shot.
Car: 87 IROC - 67 Camaro
Engine: 383 TPI - ZZ4 TPI
Transmission: 700R4 in both cars
Axle/Gears: 3.27 - 3.36 posi in both cars
I agree with the thread starter!!
A 2.0 60' is good.
I made 5 passes on my 87' IROC with a set of drag radials 3.27 rear gears and a stock 700r4 no stall converter.
First 4 passes I started from a DEAD idle and got 1.915, 1.995, 2.015, and 2.020 for 60' time.
Car ran a 13.29 at 104mph.
My 5th pass I tried raising the rpms before launch to 1200 and went up in smoke 2.5 60'.
I was extremely happy with my 60' times considering I was running with rear tires incapable of handling my HP. And thanks to TPI setup, my motor NEVER bogged at launch!!!
Compare this to my 67' with the same trans, rear gears, and same set of tires, best 60' was 2.13 but it varied, not as consistent as my IROC, which has better rear suspension.
A 2.0 60' is good.
Car: Junk
I dont' know what to tell you guys, but I go to the track quite often, and the only people I see cutting 60 fts quicker than 1.90's are running SERIOUS times, like low 12's or quicker. I just think that some tracks are different..........Maybe the way the lights are setup, or how much VHT they use....altitude.....ect.....My track is at 3,200 feet....so does that mean i use a correction factor on my 60ft to compare timeslips???? I always just read off the slip. honestly I think its great some of you guys are getting 1.7 or better 60 ft with high 13 second or slower cars, but here in Tucson it just does NOT happen that way. Maybe we just all don't know how to drive....or maybe its differences in tracks, I don't know.
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
My car is only low 13s... best 60' is a 1.720 and I have yet to even touch the suspension. I realize it is not an auto Fbody, but it is not a wild 12 second car either. The 60' has no correction factor, so it should be the same at every track, as long as traction is the same.
TimZ2882, I think in your case your car just does not have the power to need slicks. I had an auto in my car and when i had DRs on, it would bog so much off the line, I would pull in the 2.3-2.4 range. My car at the time was running low 14s, so imagine a mid to low 15s car, with slicks... Not trying to be mean but I think it is the truth, its overkill...
Car: 89 20th Ann. TA
Engine: Turbo 3.8 V6
Transmission: 200 4R
When I bought my car, it was stock except for a chip, thermostat, and K&N. I went 13.0@104. I ran 5 times and the 60' was 1.88-1.92 on all runs. That was with Firestone Firehawks.
After doing all the normal mods, I went 12.1@111 on Nittos. This was still on stock injectors, turbo, downpipe, cat back, etc. Short time was 1.69.
After doing a turbo, injectors, downpipe, cat back, etc. I'm at 11.6@115 on a 1.62 short time. Still on Nittos.
I think my car is making a little more HP than yours and the drag radials can hold. That is just not a fair statement to make about the tires.
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
Originally posted by TTA 1387
This I find hard to believe. What drag radials can't handle a low 13 second car?
Originally posted by 25thmustang
I agree usually the driver not the tires that cause the issue. I have seen mid 1.9s and even heard of 1.8s on street radials.
On my 96 WS6 Formula, I cut 1.87 on the stock GSC's. That was 4.10 and 6spd. Most were in the low 1.9x range.
It can be done
A set of good slicks at 4-5 lbs would allow me to raise rpms at launch.
My IROC is totally CA smog legal and I ran the car that way at the drags. I was very pleased with my times, there are not very many smog legal cars on the road that can run in the low 13's with street tires!!!!
I use to race a 69' Z28 33 years ago in a stock class (NHRA G-Stock) and I know just what good slicks can do for your launch. With cheater slicks I ran low 13's. Slicks dropped me down to 12.6. But back in 1970 NHRA rules would not allow slicks in stock classes.
I don't want to get into a pissing contest with you, but you obviously didn't understand anything I said. The only thing holding my CALIF. SMOG LEGAL single EX. IROC from running in the twelves is the drag radials. Actually I don't think DRs give you much more traction than good street tires. You can't lower the pressure down below 15 lbs because you can't stud the tires to the rims!
When I started modding the TA, it ran 12.6@110 on Firestone Firehawks. With no changes except drag radials, I went 12.1@111. The difference was launching harder. 1.88 to 1.69 short times and no spinning on shifts.
Drag radials work. And I run 20-22psi in them depending on track conditions.
Not knocking your car, just your drag radial statement.
Rob:
Did you notice in my original post I stated that my 87' IROC has 3.27 rear gears and a stock 700R4???
Here is another example: On my first pass, I ran against a 2003 Viper. His time is on my time slip. He had what looked like 14" wide rear tires and of coarse a manual trans, I have 275/50 DRs (10" wide).
----------Viper ------- Me
60' -----1.953 ----- 1.992
330' ----5.252 ----- 5.606
1/8 -----7.874 ----- 8.612
MPH ----96.12 ----- 82.25
1000 ---10.108 ---- 11.189
1/4 ---- 12.009 ---- 13.295
MPH --- 116.88 ---- 104.87
This backs up my point, a 1.9 60' launch is pretty damn good for DRs.
1.9 60' good for drag radials? That's miserable.
Most guys around here have no trouble hitting 1.7s and 1.6s on 16" and 17" drag radials on emissions legal street cars. Drag radials in general can hold a high 7 second 1500HP car, so I'm sure they'll handle your car. The problem is in the rest of your car (converter, gearing, suspension), not the tires.
Rob:
Rob:
Now I'm running a converter, bigger turbo, bigger injectors, exhaust, etc and so far the best is a 1.62 on Nittos.
You really should be cutting better than 1.9x with a 15" drag radial. Mine are still on 245/16's. Better sidewall on the 15".
You are not reading all of my post either. I stated that my 1.9 and 2.015 60' times were from a dead idle. And my motor did NOT bog. I then tried a 1200 rpm launch and went up in smoke with 2.5 60' time. What does that tell you? The tires can't handle the HP!!!
Its not the tires can't handle the HP. More like your car, or you, aren't setup to get the best out of it.
Well, I guess your right Rob, I don't know what I'm doing. Even though I drag raced for years, and held the 1970 NHRA worlds record in G-Stock optional at 12.73 ET 107mph. At the same time, my buddy Steve King held the worlds record in AHRA formula I F auto stock class at 11.23 128 mph, he also won the Winter Nationals in 1969,1970, and 1971.
Anyway I'm going to sign off, but I still do agree with ChrisFormula355, the original thread starter.
No need to claim what you did over 30 years ago as it doesn't apply. Technique has changed drastically since then as well as tire technology. Slicks back then are normal street tires now. Everything, for the most part, is so much better than then.
But I still say a 13 second car is not making enough power to say drag radials don't work.
Rob
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
and to counter your statement that street tires or DRs cant hold up to a good launch, i have personally cut a 1.86 60ft on street tires with a 1200rpm launch. changing over to DRs gets me mid 1.7s with a 2000rpm launch. its not the tires, its either your launch technique or your cars setup
Car: '92 1LE
Transmission: 4R700
Running 2.0 or 1.9 short times with drag radial is unimpressive. Using the advantage they give should net much better results than that.
I ran inconsistently on old 235/60/16 Goodyear Eagle RSAs and generally landed 2.1-2.3s as I learned how to launch. I replaced them with 245/50/16 BF Comp KDW tires. I've only made 3 runs on these- 2.106 @ 28psi, 2.019@26psi, and 2.056@25psi. I expect pretty consistent 1.9xs with a little less pressure. I'd expect a solid tenth or so from DRs. Running slower 60's on DRs in a modded car is unforgiveable.
This is at Moroso in Palm Beach County in a 170,000 mile '92 1LE with no mods.
Drag radial tire equipped cars are capable of 7 second quarter mile times on stock style suspension. BFG dominates, but the Nitto tire'd cars have run into the 9s. I'm sure someone would hit 8's if they would switch they're BFGs over for a few runs.
This is a local guy who I know personally:
http://www.50mustangandsuperfords.co...8_0306_little/
And he is not the fastest DR car in the country. From 2001-2003, he was. Now there are several others going faster.
And as a side note, the car IS street legal.
And if you think these banzai runs are flukes, I assure they are not. While some others have trouble dialing in there times, Chris is DEAD CONSISTENT!
It isn't the tire thats lacking here...
Car: 2004 BMW 330Cic
Engine: 3.0
Transmission: 6 speed
unfortunately what was accomplished 30 years ago is not that pertinent to this topic.
Today's tires are much stickier than the used to be.
As far as 2.0s on complaining...it all depends....2.0 @ 100+ mph and you need to work on it. 2.0 @90-95 mph, that's sounds about right.
I personally run 1.9x on $hitty street tires, slightly better than a buddy of mine running 1.9x with an LT1 Z28, with similar et and mph as me. Kinda embarrasing for him that I beat him out of the hole on my street tires, but i attribute that to the suspension work I have done, along with driving technique. I expect to run in the 1.8x range with DR this summer.
Hookinp up at the track is dependant on a number of things, HP/torque, suspension setup, tires, technique, and track prep.
My car on a non prepped track runs in the 2.1-.2.2 range sometimes even worse.
Car: 91 Z/28
Engine: 6.3 L98
Transmission: TH350 4500 STALL
Axle/Gears: 3.73s
Originally posted by 1bad91Z
11SEC91Z - was that 60 footer on nitrous?
Car: 89 Formula 350
wasnt the original poster just stating that he didnt think people with 14 sec and slower cars should be complain about about 2.0 60' times. I took his statment as meaning that cars that dont have the power to break into the 13's or better should put this off on there 60' time unless there spinning out of the hole. If the car dead hooks from the hole and pulls a 2.0 thats good for a car that makes low 14's or slower. If its a 12 sec car turning 2.0 60' times then yes I could see that persons point not being happy with there 60'.
As for the guys saying 1.9 with DR's suck. I see his point they can pull much better 60's but that comes down to the car and track prep.
Car: '82 Z28
I got a 2.19 60' on 215/65/15 tires
Better than I thought it would do lol (was thinking it would do 2.4x 60' footers) also ran a 15.21 @ 90 which was worse than I thought
This was with the 305 still in the car.
This was with the 305 still in the car. I agree with Chris, 2.0 is damn good and I believe it has to do with the track more than anything. I dont know if the timing lights are a variable (rollout distance, etc) but launch pad surface and prep must be.
Here in So Cal, at carlsbad raceway, a 1.9 60 foot is smokin' quick... I had thought about what Chris is talking about numerous times and sometimes joke that the 60' is the difference between internet times and real times. 1.9 cars here are deep into the 12 second terroritory (f bodies anyways)
I have personally never seen under a 2.1 60 foot in my car and I have D/Rs and every rear suspension mod possible including a locker rear. My car is no slouch either.
Ive also run at moroso in palm beach and I did manage 2.0's in a 19 second 4 banger pickup truck with 4 different used tires and massive wheel hop (like enough that my buddies said the bed was visibly jumping up and down)
So I dont know what it is
Car: 87 IROC (low 12's)
Engine: 400 sbc .040 over
Transmission: 700r mod
Re: LOL
Originally posted by wingnut
And I thought that I had some severe tire spin. Check out my sig, I should be running 12's.
MDFormula350 just went 1.8 on regular 17" radials (not DRs) in a high 13 second, internally stock L98 car. Just exhaust and suspension mods. Check his post out in this forum...
That is hooking no doubt, but that is pretty much the norm out here. Maybe you west coast guys are doing something different?
Car: 89 Formula 350
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
2. drop pressure
2. drop pressure
Droping pressure wont help you out much with low profile radials. the sidewalls are so stiff that to get the tread to widen out any significant amount you have to run very low pressure which in the best case will cause more drag at the top end, the worst case youll throw a tire.
Heating up a street radial doesnt do anything. You heat up slicks because they are designed to work hot. The only thing u do by heating up street radials is to clean the tread off and waste rubber. A SHORT spin of the tires on the way to the line is sufficient for a street radial.
I agree with your last two points. Practice makes perfect.
Some people here may not agree with what im saying but are they pullin out 1.8 60fts with cheap rubber?
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
last sat i went to the strip.
normally i run street tires, full air, swaybar, everything as she sits on the street... this is just a benchmark thing for me, not a drag car.
well.... the previous friday, i changed my gear oil in my 4.11 rear i JUST bought. i found the edge of 6 or 7 teeth on the magnet.
fug.
so we decide to just run it hard till it breaks (i had 2 backup rears anyway)
i yanked the swaybar, put the shocks from my old car on (nice and worn) and got some very worn comp TA drag radials from a friend.
first launch.. like street tires... 2.2 60' i felt as soon as i let the clutch out that i should have launched harder... i had a ton of traction left...
second.. 2.0 60' and i still felt i could launch harder......
third.. hooks JUST right.... for half a second.
my rear let go with a boom so loud that the car jumped in the air and everyone who saw me told me they heard it....
i trailered the car home...
in anycase, ive ignored this whole thread for one reason.
if you mod your car at all and run sticky tires, you shold be below 2.0
heck the SAME tires i had on that night went 1.7s with another similar car... (except he has a T5 , i have a T56... he'll need a T56 soon lol.)
i see cars with gears and a converter do it all the time...
if you have any significant desire to make the car capable of going below 2.0, you can.
and just so you guys know, cooper is consistantly the worse prepped track ive ever been to. its BAD. as proven by Gtech, i cut better 60's infront of my house. the only reason i go is because its close.
fug.
So yeah, not sure I'm in the group of people you guys are talking about.
