estimation for my car... need to know
Car: 1986 Pontiac Trans Am
Engine: LG4 305
okay.. tell me what you think i'll get
305 LG4 engine in base firebird (no power options)
2.73 open rear
edelbrock headers, huge y-pipe, hi-flo cat, 3in cat back, open element.
auto
good treaded tires.
132,000 miles on engine. puffs a little blue smoke when started... any ideas?
2.73 open rear
auto
good treaded tires.
Car: 1988 Camaro Sport Coupe
Engine: 305 TBI
this is a side note but i dont know if u know but blue smoke usually means ur exhaust seals on ur heads are goin bad, id say 16s also
Transmission: 4L80E/4L80E
Mine was similar when stock except no headers (and I replaced the valve stem seals). With 3.08 open rear, letting the transmission shift itself, over a season of tweaking it got down to sea level corrected 15.7's.
Your car is probably a little heavier (I was going down the track at just under 3500 lbs), and your gears not quite as good, so I'll say the same 16's that others are estimating.
