Just bought a 3rd gen - what will it run?
Car: 88 Pontiac Trans Am GTP
Transmission: 700R4 w/3.27 gears
Hello,
I'm a newbie to these boards.
I just bought a 3rd gen and wanted to know what range does it typically run in the quarter mile.
The car is a 1988 Pontiac Firebird GTA.
It has the 350 L98 and 700R4 trans with 3.27 gears, aluminum drive shaft, and posi-traction. Completely stock!
Assuming the engine and tranny are in good shape, what will it run?
Thanks for your time
Car: 1989 Formula 350 / 2000 Lightning
Engine: GM HO 350 Crate (Vortec headed w/TPI) / SC 5.4 330
Transmission: Rebuilt 700R4 (Raptor Rebuild Kit)
Welcome to the Forum...
The L98's are known to run anywhere from 14.5 to 15.0's. Enjoy your new found POWER!!!
TORQ RULES!!
Later
TORQ RULES!!
Later
From: Tomball Texas, right outside (north) of Houston
Car: 1990 GTA and 83,99,02 Trans Am WS6
Engine: 350 TPI,CrossFire 305 and LS1
Transmission: 4L60 and 700R4 and 4L60E
Axle/Gears: 90-3.23,83-3.42,99-3.73,02-3.42
A GTA with a 350 should run a high 14 stock
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Car: 1984 Z-28
Engine: L69
Transmission: 700-R4
Since you just got the car, I'm going to suggest you get some sub frame connectors for it (unless it already has them). Others will tell you this should be the first mod you do. I wish I would've known that when I first got my car.
With that said and done, I'd agree with steven90gta, depending on your elevation.
Car: 2000 Trans Am and a 85 Iroc-Z
Engine: The Mighty LS1& 305 just beat meTPI
Transmission: 4L60E and 700R4
With traction i am thinking mid 14's, maybe on a freak day you'll hit a low 14. Hey its happened before
Car: 1989 Iroc Z L98
I am running well into the mid 11's pulling the front left with stock suspension and chassis in an 82 Camaro, my only real chassis "mod" being a 10 point cage to make it NHRA legal for 11's.
On 275/50/15 BFG radials, the car cuts 1.8 60 foots with stock location LCA's, stock torque arm, stock front and rear shocks, stock coil springs and with iron heads and the battery in the front of the car.
A lot of people on TGO make a bigger deal about big $$$ suspension and chassis modifications than they should is what I am getting at.
Car: 00 Trans Am/89 IROC
Engine: LS1/L98
Transmission: 4L60/700R4
Originally posted by prOject-IrOc
if you can drive mid-to-low 14's. cmon people, my car is living proof. True it's a 90 and has a couple extra horses, but with just a muffler i ran 13.9.
Aren't IROC's a couple hundred pounds lighter though?
I always thought pontiacs were the heavier of the 2 divisions
Car: 1988 Pontiac GTA
Engine: 5.7L TPI
Re: Just bought a 3rd gen - what will it run?
Originally posted by Ravicai
Hello,
Hello,
Got a carfax on it and it got just a little over 105K on it as it was not driven much for the last 7-8 years...had a clear record too
Funny story about this car and who we think owned it...but I'll let my son tell that story
if he wants too.He got it running and the engine sounds good and strong...LCD odometer still does not work and looks like the last owner hit something and bent one of the a-arms but I will have to check it out this weekend when I go over to his house....will have to check the subframe recommended mod as mentioned too...was going to buy this for myself but I already have a big project going on my 96 GMC K1500 which is getting a built SC 383 engine
Here's a movie of it blowing away a 90 350 IROC with the tired 130K 350 engine that was in it
OH and in 4HI all the way down the track too....new engine/combo should have another 150HP...hmmm?MOVIE LINK: K1500 vs 90 IROC
Son you need to post some pics of your new ride too
Oh...guess I am a newbie here too
Got to love this Forum/Tech treasure chest too!Dad/Ken
Car: 2002 Formula Firebird
Transmission: 4l60e
I know a guy that has the same combo as you. With free mods and a set of headers (rest of factory exhaust modified to fit the headers...horrible job) he ran a 8.7 in the 1/8th mile. That is a high 13-low 14 second pass possibly.
He has low miles though.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Originally posted by unknown_host
It should be explained that about the only thing SFC's will do for a 15 second car is take a few squeeks and rattles out of the interior noise situation.
theres a reason your car pulls only ONE wheel off the ground.
for a street car, SFCs are a great idea because they keep the car stiff and rattle free... you actually get a smoother ride.
but everyone (that i saw)left out the most important thing you can do when you buy a new car....
change the plugs, cap, rotor, possibly the wires, fuel filter, oil, oil filter, coolent (dont flush unless its really bad, if you flush, use sealing tablets or bars stop leak)
clean the engine bay out so you can see any fresh leaks... and check your timing..
thats generally the first thing id do with a new car...
Car: 91 Camaro Vert
btw, running at 210* on a humid night my friends 91 Z28 (same motor as yours) that he just bought ran consistant 9.1s in the 1/8th with a best of 9.03
Car: 1984 Z-28
Engine: L69
Re: Re: Just bought a 3rd gen - what will it run?
What did you do to that truck? Moderator
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I had to watch the video to see what you were talking about. I would have guessed the truck would have won anyway just from listening to the Camaro's burnouts. It had no traction even after heating up the tires. When you hear tires squeeling even when trying to do a dry hop, there's no traction. It doesn't take much to beat someone who has no traction no matter how much HP they claim to have.
I've taken out Camaro's and Mustangs with my truck also during street legal nights. Make a bunch of passes running low 15's then get paired up against one of them and hit the NOS button for a low 13 second ride. Not too bad for a daily driven 4600 pound truck but it's still boring compared to my car.
Fast355
Dec 2, 2016 06:33 PM
86IROC112
Sep 7, 2015 01:37 PM
