Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
rpm problems...
Old Aug 6, 2004 | 04:36 PM
rolling-robert's Avatar
Car: z-28 x2
Engine: 355ci and 305ci
Transmission: th350 and th350
rpm problems...
from idle to 2000 rpm it has a pretty strong take-off, BUT from 2000 until 4000 rpm it kinda falls back, then after 4000rpm it gets a bit stronger again.
it is the 87 camaro in my sig WITHOUT the 4.10 rearend (2.93 at the moment)
what can it be?
timing is about 14 advanced
i make 1/4 mile times of 15.34 at the moment so there is lots of work to do, huh?
please help, i built this car in 4-5 years, only to be 0.50 seconds faster then my 84 camaro
chevy camaro z28 1984 305ci carb th350
chevy camaro iroc 1987--> '77 355ci/crane 272/rollerrockers1.5/9.72 forged pistons/ported '66 vetteheads1.94,1.5/dynomaxheaders/holley600/th350/shiftkit/hughes2500stall/dana60/4.10
Old Aug 6, 2004 | 09:01 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Sound like a fuel problem. Try raising the float levels in the carb. Put jet extensions in the rear bowl.
You also need at least a 750 carb to match the rest of the stuff listed in your sig. Good heads, high compression, good exhaust, moderate stall converter mixed with a tiny carb. The 2.93 gears aren't helping either.They're not allowing the engine to pull quickly into it's powerband.
Elephantismo
Feb 13, 2019 12:51 AM
ULTM8Z
Oct 2, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
Damon
Sep 26, 2015 04:29 PM
