Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Will I hit 12's
Old Mar 5, 2005 | 07:14 PM
Huffs_91_RS's Avatar
Car: 84 Z28
Engine: 383
Axle/Gears: 342 Posi
Will I hit 12's
Very curious.
I have a 350 bored 30 over, running Vortec heads, pistons are approximately 10:2:1 compression ratio with my heads, air gap intake, cam is a comp extreme energy with a lift of .487/.490 at 1600-5800 rpms, carb is a Holley 600.
Trany is a 350 turbo with a shift kit, 2200 or 2300 style conv., trans cooler, and mega shifter.
Rearend is a 342 with posi, tires are 245/50/16's
Thanks for any replies.
Old Mar 5, 2005 | 08:37 PM
Car: 84 Z28
Engine: 383
I'm not sure of the weight. Its stock with me, and I weigh 205. All smog stuff removed.
Old Mar 5, 2005 | 08:54 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
If its tuned right, you have traction and its driven well, you'll probably see mid 13's...You might wanna step up to a slightly larger carb though(650/700cfm) just my opinion though.
Old Mar 5, 2005 | 09:02 PM
Car: 84 Z28
Engine: 383
I've thought about a bigger carb. Not in a rush oh. Wanna know what it will do with what I have. Going to the track when it opens. 13's are not bad oh. Thanks for ur opinion.
Old Mar 5, 2005 | 09:34 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
you can get more with them vortec heads. Here's what i'm going to run should be in the 12's
350 Vortec Build Up
HEAD WORK
Cut the guide OD to .530", so you can use the Teflon valve guide seals. You should also get the stock pull-out studs pulled out, and the holes milled & drilled & tapped for screw-in studs; and use good quality studs, and guide plates. That way you don't have to use self-aligning rockers. Your choices are much more varied.
Push Rod whole’s have to opened up to .500” or ½” to suffice for the 1.6 Rockers
Carb
750
Crank
Scat 9000 Crank Crankshaft 350 Chevy Chevrolet sbc=200$
Cam
XR282
Rockers
Comp 1302 1.6 roller rockers
Valves
Manley "Street Flow" valves, with undercut heads
Just some research i have right now on everything. Haven't started the build up yet but some of that should help you out. I'm still learning. Just showen what others told me
Old Mar 5, 2005 | 10:06 PM
Car: 84 Z28
Engine: 383
Thanks!! My motor is togther and in, so I'm not going to bother with anything, but maybe the carb. The heads, if I were to do all of that I would probably go with the alum. vortec heads. for the I'm still learnin to man. Thanks for the INFO.
Old Mar 6, 2005 | 09:05 AM
plumminfool's Avatar
Car: 1988 camaro sport
Engine: 355
Transmission: 5 speed
Axle/Gears: Ford 9 inch - 4.11 gears
I run a 12.69 @ 107.65 with sportsman 2 heads and a Demon 750 carb. My car weighs 2970 lbs. 10:1 c.r. 28/9.0/15 M/T ET drags. 3.73 gears with a 5 speed.
RedLeader289
May 28, 2019 01:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
apie2546
Oct 16, 2016 02:24 PM
RS Reaper
Sep 27, 2015 07:04 PM
Twinn Engines
Sep 25, 2015 06:27 AM
