Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
310 what'll it run?
Old May 12, 2005 | 04:08 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
310 what'll it run?
Just trying to get some ideas of what the car will run, have beentrying to get it finished for a whil and i'm almost done. So here's the specs.
1984 Z-28 t-top car
305 bored .030
KB pistons (domed) supposed to be 11.0 : 1
stock H.O. heads from 84 changed to 1.94 valves, ports cleaned up, and reworked to match headers and intake manifold
@.050 224/228 lift 460/468
1.5 full roller rockers
wiend 7546 single plane intake
1 5/8 full length headers 3"collectors
650 cfm holley dp
th400
fully manual vb
3500 stall
3.73 rear gears
car has been gutted inside have dash shell left, and race seat
8 pt cage, sfc, adjustable rear suspension parts
28x9 slicks
nos 75-150 adjustable
Old May 12, 2005 | 04:46 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i'm gonna say low 13's high 12's.
Old May 12, 2005 | 05:25 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
thanks, wanting to try and make the 310 work for a while and get some gremlins worked out before i step up to a high hp motor. Will probably flog the cr@p out of this engine and see how slow it'll go
Old May 12, 2005 | 07:17 PM
mw66nova's Avatar
Engine: 7.0L
i tell you what, i beat the ever living crap outta my motor and it still keeps on ticking just fine! oil has never had any metal in it and i wrap this thing up to 7200rpms occasionally. the 305 is a great base to build a motor you want to learn on. that's why i did mine. mine has forged rods in it for insurance, but other than that, it's pretty much built with stock replacement stuff...other then the cam/roller rockers/timing chain/pushrods...stock crank, stock replacement l69 pistons (.030 over) and stock 416's. let me know how yours runs. i hope to be in the 13.3's by the end of summer without much mods from where i sit now.
Old May 12, 2005 | 09:10 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
dumb question, i didn't think about before, those times your thoughts with our without nos.
Old May 12, 2005 | 11:04 PM
mw66nova's Avatar
Engine: 7.0L
for yours or mine? mine will remain n/a for a while. i think that yours should run low 13's/high 12's n/a. i think that the th400 will hold you back though.
Old May 13, 2005 | 07:39 AM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
what trans should ii go with then? I was running a t-5, but it REALLY didn't like launching with slicks, it finally broke bad, and afterwards i heard that is why they never put the t-5 behind the 350, was because they were only rated for like 300 ft. lbs...is that right?
Old May 13, 2005 | 11:42 AM
mw66nova's Avatar
Engine: 7.0L
i think that a th350 would work much better. they take alot less power to spin and can be build to hold plenty of power without costing huge money. i got a built 700r4 from a guy local to me for cheap. so, i am running his 700r4 and 4.10's out back on a 28" tire.
Old May 13, 2005 | 12:31 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
That's how i ended up with the 400, traded some stuff for it after my t-5 came apart. Had some parts put into the 400 to lighten up rotating weight, i thnk he dropped about 8 lbs off of it. Just curious, cause it seems your car is alot along the lines of mine, what are you running for a rear suspension setup.
Old May 13, 2005 | 12:38 PM
mw66nova's Avatar
Engine: 7.0L
stock torque arm with a poly bushing on the tranny. stock lca's that i boxed in using 16ga steel. stock v6 springs. monroe replacement shocks. spohn non-adj panhard rod with poly bushings. 275/60/15 m/t et street radials.
seems we have a few things in common. i play drums as well...
Old May 13, 2005 | 12:59 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
How often do you get to the track...A few years ago i was running every weekend at 2 or 3 day events .....got burnt out and stopped driving for a while...ready to get back into it now, on my own terms and schedule
Old May 13, 2005 | 04:46 PM
muggsyjack's Avatar
Car: 1992 RS Camaro bracket car
Transmission: TH-350
It should have no trouble getting into high 12's. We are running low 8's in 1/8th mile with the following:
POS 305 stock bore (POS because there is a huge ridge at top of cylinders)
Original pistons.
Standard rings (top ring does not seal due to ridge.
801 heads off 267 that carry 1.94/1.50 valves, quickie porting and matching job.
Blue Racer 230 dur./.465 lift cam, hyd. w/1.6 roller rockers (.496 net lift)
1-5/8 hedman long tubes w/15'collectors.
air gap dual plane w/750 VS Holley.
Electric water pump.
5000 stall Edge converter (5400 stall behind 350)
th-400 w/rev manual valve body
9" Moser rear w/430 gears
29.5 X 10.5 X 15 MT slicks
The engine is a substitute for our stronger 350 (currently being rebuilt). Even with everything optimized for stronger 350, the 305 ran an 8.01 ET in 1/8th mile w/1.72 60'. If we did a bore job and used a shorter tire and TH-350 trans, it would have easily ran in 7's.
Contrary to popular opinion, there is nothing wrong w/305. This started life in car and was rescued when 350 dropped oil pressure due to weak thrust bearing.
Old May 13, 2005 | 05:03 PM
mw66nova's Avatar
Engine: 7.0L
not as often as i'd like. i'd really like to go every week, but i work alot at night and so it makes it difficult. i am also having some issues with my carb. the last time i went to the track, i fouled two sets of plugs and didn't get any good times in. oh well.
Old May 14, 2005 | 09:37 AM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
I know what your sayin, the only reason i built the 305 was because people (5.0 drivers) said that the only reason that they were getting beat was because all of the camaro's were almost 50 cubes bigger, so i decided to beat them with a small motor, and see what there excuxse was then Anyway, my goal is to get the car into the low 12's n/a, then be able to bottle feed it into the low 11's maybe even break into the 10's
Old May 15, 2005 | 01:11 AM
mw66nova's Avatar
Engine: 7.0L
i built mine to beat 350 owners. honestly, wished i'd built a 350. i gotta good solid bottom end though now, so i think that with some ported heads, we'll have something interesting.
Old May 31, 2005 | 01:35 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
Finally made it to the track, off of the trailer went 13.6, on the motor, tuned on it for a good part of the day finally went 13.1 on the motor, went easy with the nos at 100 hp, and got to 12.3, have a set of heads setting around that i am going to play with to see if i can get it into the mid 12's on the motor, although i'll prbably have to step up the cam as well. I'll keep it updated.
Old May 31, 2005 | 04:26 PM
mw66nova's Avatar
Engine: 7.0L
heh, what did i tell ya?! great job man!
i'd like to see a 12.9 n/a though.
Old May 31, 2005 | 04:47 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
Thanks! Worked pretty well to suprise the s**t out of a few of my friends running 5.0's. They have seen the car in build-up over the past year and said there was no way that i could run with them let alone beat them. They've changed their tune quite a bit after walking all 5 of them, 4 of them without the bottle, the other one took some work...I couldn't get him with the 75 shot so that is when i went to the 100, not to mention i killed him on the tree....I think he forgot to set his alarm clock....he had about a 1.0 rt, even so if we would have left together i would have beat his best time by a tenth
Old May 31, 2005 | 09:02 PM
muggsyjack's Avatar
Great times. What are your 60' and incremental times? A dual plane would possibly help a lot. Would improve power low. We drop with single plane. You could even try 1.6 rockers if you have enough clearence.
Old May 31, 2005 | 10:15 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
I tried using a dual plane, but my plugs were way to uneven with the nos. I'll have to go and pull my log book to check all of my stats for sure, but i think 60' was 1.7x probably not going to push it much harder for a while i don't know how long the 10 bolt will hold up, even with a solid pinion sleeve and a rear cover with cap screws. hopefully through the summer so i can finish the 9" laying in the garage.
Old Jun 1, 2005 | 01:03 PM
rokn91rs's Avatar
thats a pretty good time what track did u go to.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
