Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
power gains
Old Nov 16, 2005 | 07:57 PM
3rdgen92maro's Avatar
Car: 1995 Firebird Formula
Transmission: Th350/4k stall
Axle/Gears: 10 bolt with 3.42s
power gains
i have a 1991 z28 L98. im planning on getting a set of slp runners, headers, custom ypipe, and a hooker cat back exhaust. and strap a 100 shot of juice on it. what kind power gains will i see and what kind of ETs. thanks
Old Nov 16, 2005 | 09:03 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
Re: power gains
You should be running mid 14's with your almost stock L98 or better since you have the Speed Density car.... The mods you listed above should be good for around 25-30 hp. Et's should drop .5-.6 without nos. If you do the runners, do the intake manifold as well, and you will see much better gains. Not sure about the nos maybe you would drop off around a full second never tried the spray. I do know from experience Headers/Cat-back/runners/Manifold are good for around .5-.6 off your 1/4 times.
Old Nov 16, 2005 | 11:07 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
speed density doesnt like mods as much as MAF..
the custom tune will be crucial... but i'd say a solid 375-400crank hp on spray
Old Nov 17, 2005 | 06:19 AM
Car: ws6
Engine: ls1
Transmission: m6
True but stock for stock they were a tad quicker.
Old Nov 17, 2005 | 02:08 PM
brutalform's Avatar
1 full second, to 1.5 off your E.T. with the nitrous will most likely be the result, with good traction.
Old Nov 17, 2005 | 05:08 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
True! Once, nitrous made my car run 18.55 @ 55 mph. Expensive day!
Old Nov 24, 2005 | 11:18 AM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
He's running a carb...
Old Nov 24, 2005 | 12:06 PM
brutalform's Avatar
Who is "running a carb"??
Old Nov 24, 2005 | 02:23 PM
Blu91Z28's Avatar
Car: 1991 Camaro Z28
Engine: TPI 5.7 L
Transmission: 4L60 w/Vigilante 2,400 Stall
Axle/Gears: Girdled 10 bolt/3.23's
I'm still running my factory prom. Then again, I'm still running the factory runners too.
I'd say mid-high 13's on the engine. Well into the 12's on spray. You may want to invest in some suspension mods and tires as well.
Old Nov 24, 2005 | 04:40 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
yeah but i bet there is some left in it. boltin on runners and new base and such will make power but i think MAF will respond better to those mods than speed density. not to say speed density cant take to mods, just not as well as MAF. its just what i have read around.
and the tune for the nitrous is really what will count
Old Nov 24, 2005 | 07:30 PM
Blu91Z28's Avatar
Engine: TPI 5.7 L
There may be a little but I trap higher than most cars I see with similar mods. I've read that a million times how MAF cars respond better but I don't see how you can actually prove it. I think it really boils down to the individual car. I've seen it go both ways. As far as tuning goes, I just use fuel pressure and base timing and it seems to work OK for me. I'd like to try a TPIS Big Mouth base and runners and add more fuel pressure and see what it does. Right now, my pressure's at 43 PSI with the bigger injectors. My engine has 206,000 on it now so I highly doubt I'll let it go another year without an engine build. I'll definitely need tuning then!
Old Nov 25, 2005 | 12:35 AM
TBI92Camaro's Avatar
Car: 92 Mustang Coupe/89 Camaro RS
Engine: 5.0 carb'd/305
Transmission: T5/T5
Axle/Gears: 3.73 and stock TrakLok/stock GM
His L98 is still bone stock.....not carb'd thats his RS.
the SLP runners wont help too much without some porting on the intake manifold...then they'll pick you up quite a bit.
I say with GOOD full exhaust and N/A (provided you hook), you should be aorund high 13's with some practice runs.
What brand Nitrous you using? It makes a differance. If you use Nitrous Express/TnT, you'll get the hardest "hit". NOs doesnt hit as hard....their solenoids are too small. anything else is total junk.
If you get an NX wet kit and put the 100HP jets in, expect to drop a little over a second off your ET's...provided you hook. My buddy went from 13.6's to 12.4'/12.5's in his gears/exhaust 04 GT Mustang....on ET streets might I add. I know another buddy with an NOs 100HP wet kit and he went from 13.3's to 12.5's with a 12.48 best....he didnt pick up as much.
Aroudn here we really only have 1/8th mile.....and rule of thumb is, with traction, you'll gain a FULL second in the 1/8th with a 150HP wet shot......thats what Ive seen from 1 Mustang and a ThirdGen GTA.
I reocmmend an NX kit as I LOVE mine and cant wait to see track times next year
BRoss99
Aug 10, 2025 05:08 PM
fasteddi
Sep 2, 2015 10:29 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ambainb
Aug 29, 2015 12:43 AM
sailtexas186548
Aug 24, 2015 10:11 PM
