Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
1990 Camaro RS
Old Dec 25, 2005 | 05:27 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
1990 Camaro RS
I have a 1990 Camaro RS with the 305 TBI in it. I know the car runs like low 16's stock. I have been told that all my mods I have sitting around are really good for this motor. I would like an estimate on what I will run after I install
-Dynomax catback
-Catco cat
-1.6 Roller Rockers
-K&N open element
-Ultimate tbi mods
The car is a five speed. Thank you very much guys.
Old Dec 25, 2005 | 05:52 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i would also get some sticky tires of some sort.
i would say that with those, and some sticky tires, you may be into the mid/low 15's...get ready to do some prom tuning though to get the optimal gain out of that stuff...it seems that the tbi motors don't really respond to mods well without tuning.
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
low 16's
Old Dec 25, 2005 | 08:16 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
High 15's
Old Dec 25, 2005 | 11:11 PM
mw66nova's Avatar
Engine: 7.0L
i guess i'm a little optimistic...but i think mid 15's would be obtainable if you could drive the crap out of the car!
Old Jan 2, 2006 | 10:34 PM
Engine: LB9, LB9
Ok now add underdrive pullies and 3 degrees of timing advance to the combo and let me know what we come up with. Thanks
Old Jan 2, 2006 | 10:39 PM
Car: ws6
Engine: ls1
Transmission: m6
Not much of a difference...be careful with underdrive pullies they have been know to make cars discharge at idel. I am going to still say high 15's, until you get some better mods you wont see much difference. Id go with headers and a better intake manifold, then you should see some results. If you do get serious with the car ditch that tbi and go for a better intake.
Old Jan 3, 2006 | 05:40 AM
Engine: LB9, LB9
How critical would a posi and 3.73's be?
Old Jan 3, 2006 | 12:50 PM
Car: ws6
Engine: ls1
Transmission: m6
What gears do you currently have?
Old Jan 3, 2006 | 06:09 PM
Engine: LB9, LB9
3.08 open rear
Old Jan 3, 2006 | 06:27 PM
Car: ws6
Engine: ls1
Transmission: m6
You would notice a big difference on the low end. With 3.73's you would most likely drop .3 to .4 off your 1/4 times. You will loose a bit of high end, and your gas miliage will be worse. BTW what are you looking to run?
Old Jan 3, 2006 | 10:03 PM
Engine: LB9, LB9
I was hoping to at least find a way into the 14's....think headers and y-pipe would do the trick?
Old Jan 3, 2006 | 10:15 PM
Car: ws6
Engine: ls1
Transmission: m6
Well....The stock exhaust manifolds really really suck on the L03. I would know I had an Lg4 a few years back. The intake manifold is the same story very restrictive. I think with headers a better intake manifold, Chip, 3.73 gears, and radials you will see very high 14's. I had an Lg4 with exhaust,headers,intake,filter, dual snorkel air cleaner setup,chip,gears, and radials and I ran a 14.9, and we all know L03 and Lg4 cars are very similar.
Old Jan 3, 2006 | 10:46 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
its gonna take different heads and camshaft to be able to get into the 14's with an LO3 along with the intake mani and exhaust parts mention'd along with some computer chip tuning.
Old Jan 4, 2006 | 12:51 PM
Car: ws6
Engine: ls1
Transmission: m6
It will depend on the tune of the car.
Old Jan 4, 2006 | 04:51 PM
92MaroRS's Avatar
Even with good tuning, i dont see a stock headed LO3 hit anything faster than a low 15.
Old Jan 5, 2006 | 08:01 AM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
That one guy ran a 15.3 stock with his t-5 transmission. I'm guessing mid to low 15's. How many miles are on her?
Old Jan 5, 2006 | 07:46 PM
Engine: LB9, LB9
thats the joke.....175,000 miles.
Old Jan 6, 2006 | 06:21 PM
Car: ws6
Engine: ls1
Transmission: m6
It all depends on the driver,conditions, and the tune of the car. All of those miles is a disadvantage if the previous owners were harsh on the car. With all of those mods Exhaust,intake,chip,gears,radials, ect you COULD run a 14.9, BUT dont plan on it. Id plan on 15.3's and if you do better at least you wont be disapointed. L03's are tough engines to build beacuse unlike the HO Ford 5.0, the L03's have a tiny peanut cam, and very restrictive heads. That was why I ditched my old LG4 beacuse it didnt have much potential. My full bolt on LG4 was only running 14.9-15.3's, and it had low miles. Now my full bolt on L98 runs 13.5's all day long. If you are looking to race id get a better motor, or think about engine work heads,cam,blower ect
Old Jan 6, 2006 | 10:55 PM
92MaroRS's Avatar
Actually the reason the ford 5.0 does so much better than the chevy 5.0 is because the Ford uses a 4" bore where as the chevy uses a 3.75" bore, the extra 1/4" allows for better flow around large valves.
Old Jan 7, 2006 | 03:44 PM
Car: ws6
Engine: ls1
Transmission: m6
Everything about the ford 302 was better than the chevy 305 pretty much.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
gta90
Sep 15, 2015 04:00 PM
Street Lethal
Aug 14, 2015 08:25 PM
Sanjay
Aug 12, 2015 03:41 PM
