dana 44
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
dana 44
who made this or is it factory?
eBay Motors: 82 THRU 92 CAMARO TRANS AM GTA SLP DANA 44 REAREND (item 8054087464 end time Apr-12-06 15:16:54 PDT)
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
They were an over the counter part sold through the GMPPC. It was never offered in a production vehicle but SLP put them in the Firehawks. GM hasn't sold them for many years but when they were offered, the selling price was in the $1200-$1500 range. At the same time, an aftermarket 9" was around $1800. The Dana 44 is a 8.5" ring gear which isn't mentioned in the listing.
To spend $900 for a rebuilt disk to disk Dana 44 seem like a good deal. If the price climbs too much then it doesn't become much of a deal when you can buy a better 9", 12 bolt or Dana 60.
Car: 1991 Firebird
Engine: 305 TBI
Transmission: 5 Speed Manual
The Dana 44 was used in the original SLP Firebird Firehawks. It was also a replacement rear end that GM used for the third gen cars. They are a fairly rare rear end for this application.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Mechams are an aftermarket conversion like the Firehawk, not a factory car. They got their Dana 44s over the counter from GM and swapped them in, too.
Thanks guys, no matter how long I keep this car I learn something everytime I log on here
This would be a fairly good rear for a strip car, light and a decent amount of options out there for them, they came in the 90`ish corvette`s didn`t they?
This would be a fairly good rear for a strip car, light and a decent amount of options out there for them, they came in the 90`ish corvette`s didn`t they? Trending Topics
Car: 1984 MSE #52
Transmission: TH700
Engine: 383 Carb
Transmission: 4L60
Car: 1984 MSE #52
Transmission: TH700
The chunck or center section with the ring and pinion is basicaly the same. But the corvette, has independent axles or IRS: and 3rd gens and the trucks with dana 44's have solid axels.
sailtexas186548
Jan 19, 2016 12:21 PM
