another what will i run and hp ques.
Car: 1928 dodge coupe, 64 1/2 mustang
Engine: 350,289
Transmission: munice 4 speed,c4
Axle/Gears: 9" 3.00, 9" 3.25
i have a 91 camaro completely gutted with a 350 std.bore, comp 305H cam, 1.6 roller rockers, port and polished heads 882 ( not not the greatest choice but very cheap) good to .600 lift, vic jr. type intake, 750 holley dp, 4000 stall turbo 350 maunal shift kit,msd 6al ,msd wires,hedmen long tubes open, 4.10 rear with spool, 26-8.5-15 mt slicks. car has no interior just one seat. by the time i get to go to the track car will have at least sfc, lca'smaybe a cage . running 1\8 track
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Alright i'll take a stab at it, 7.50's just depends on if you have enuf compression to make up for the bleed off of that cam. Good luck!!
eightsixseven
Dec 16, 2024 01:50 PM
Fast355
Dec 2, 2016 06:33 PM
