Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Attn: IHI or anyone else with an aftermarket 31" x19" radiator
Old May 22, 2006 | 06:24 AM
JFeaster's Avatar
Car: 1984 Camaro
Engine: 385 SBC
Transmission: Powerglide
Axle/Gears: 4.30
Do you have any pictures of how your 31"x19" radiator fits in your car? I'm going to order one today and wanted to make sure this thing is going to fit. I measured 33" across on the core support but am wondering about the 19" in height. I'm pretty sure I'll be ok I just don't want to have the radiator coming over the core support (height wise).
Thanks in advance,
Old May 22, 2006 | 06:42 AM
SS CAM's Avatar
Car: 82 Camaro Z/28
Engine: 383 SBC
Transmission: TH350
It's a tight fit in but the stock shroud was kind of sloppy so I made my own hold downs from alumunium bar stock and heated them and bent them to shape. Here's a pic, hope it helps you out.
Attached Thumbnails Attn: IHI or anyone else with an aftermarket 31" x19" radiator-spalfans.jpg
Old May 22, 2006 | 07:37 AM
JFeaster's Avatar
Car: 1984 Camaro
Engine: 385 SBC
Axle/Gears: 4.30
Thanks! What brand of radiator is that? Where did you get the fans?
Old May 22, 2006 | 08:45 AM
SS CAM's Avatar
Car: 82 Camaro Z/28
Engine: 383 SBC
Transmission: TH350
It's a Griffin Radiator and Spal fans. The dual 11' fans I got at McCulloch Fabricating, Inc. Specializing in Aluminum Radiators for Racing & Custom Applications
Old May 22, 2006 | 11:50 AM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
I've got a 31"x19" Griffin in my car without modification using the stock hold-down.
Old Jun 6, 2006 | 10:26 AM
11SEC91Z's Avatar
Car: 91 Z/28
Engine: 6.3 L98
Transmission: TH350 4500 STALL
Axle/Gears: 3.73s
same here,just had to lean it forward a tad bit..
Old Jun 15, 2006 | 03:28 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
step-by-step with pictures:
Untitled
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
