Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Cant hook on ET STREETS on my L98
Old Jun 21, 2006 | 10:59 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i was soo excited tonight.... finally some runs with my ET streets. they are used tires tho, but still plenty of tire tread left. rubber felt soft and looked great.
I even took off my front sway bar but left the wonderbar. i'm painting the swaybar to match the rest of the suspension
i did my usual car setup... dropped the front shock rate to softest settin
rears this time i set at 3/5 on the shocks with 5 being stiffest. street tires for me liked 4. i had 1.88 to 1.94 60's on a good day on street tires
tried the tires at 18psi... seemed to hook but i was rewarded with 1.92 60 foot.. there probly was some spin.
tried 16 psi, then 14, then 12 twice as the night got cooler. all started to hook then spin then hook. 60's were 1.91-1.93. not much better than my street tires
my topend as expected was killed off abit. runs for me were 13.94, 13.96 twice, 13.99 and 14.04. actually street tire times
my suspension is eibach prokit springs, with tokico adjustable shocks. panhard bar, lower control arms from spohn with brackets... set in bottom most hole. stock rear sway bar.
i stalled the car up on the line, as much as i could before it pushed out. one run i had the car stalled lower and just let it flash. most full stalled runs were about 2400-2500rpms or so. the flash was more like 2000rpm.
i think something is wrong with my suspension/chasis... its just not allowing the tires to hook
or could it be i have bad rubber on these et streets??
Old Jun 21, 2006 | 11:15 PM
EvilCartman's Avatar
Car: '82 Z28
How much of a burnout did you do? I know if I don't get a good burnout, my 60 foots are even worse than they usually are. Plus the back end slides around.
Old Jun 22, 2006 | 12:46 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
my burnouts were pretty good i think. i smoked them thru 2nd gear and tried to carry it out. but my car sometimes started gettin sideways on me and i had to get off it so the burnout wasnt as long as i wanted. even so, the burnouts i thought were decent hooked about the same as the ones i thought were not so decent.
should i really try a much longer burnout? i'm not sure how long to heat these things.
my car felt VERY stable tho down the track. even on the street with 18psi in the tires, it rides nice. no sloppy rear end. even with 12psi in the tires, they look pretty full and thick.
Old Jun 22, 2006 | 01:08 PM
brutalform's Avatar
My first time on ET Streets, was no better. I was getting slower 60s than I was used to with the BFG drag radials. I would recommend doing a GOOD burnout for the first out each time. Then the rest of the burnouts on that day, I would do a little better than a "light" burn out, just to put some heat in the tire, and to clean em off. Dont fret, the 60s will get better. Mine did. They started to really improve, the next two times at the track. BTW, keep playin with the pressure too.
Old Jun 22, 2006 | 02:22 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
alright sounds good thanks. i think i'm gonna try and do a longer burnout. the weather was very hot and track prep sucks. i knew my et's werent gonna be the best the car could run, but i figured i would see some idea of what it could do. i figured i would be in the low 1.8's 60 foots.
Old Jun 22, 2006 | 03:14 PM
Demon355's Avatar
Is this all with stock rear end? How much can those 9bolts take? How much could my 10bolt take, lol!
Old Jun 22, 2006 | 03:20 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
9 bolts are normally a bit stronger than the 10bolts, but i've been 1.649 to the 60'. 87 T/A said he's been 1.38!
Old Jun 22, 2006 | 03:55 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
yep... and i seen two of his runs. have one on video of that TA
but these launches are not anywhere near violent enough to break a 9 bolt
Old Jun 22, 2006 | 04:35 PM
brutalform's Avatar
Yea, 87_TA has had great success with his rear. Some guys break em, while others dont. A bit different than radials, you will get used to the biased ply ET streets.
Old Jun 22, 2006 | 06:53 PM
MdFormula350's Avatar
Just takes time, track prep would of be nice as well.
It took me 2 runs to get my drag radials workin for me. And now I do a good burnout and run the tires pressure around 20-22. Also I have been goig around the water and backing into it. try to keep the front tires as dry as possible.
I think thats one of my 1.7 60 foots.
Old Jun 22, 2006 | 07:44 PM
Blu91Z28's Avatar
Car: 1991 Camaro Z28
Engine: TPI 5.7 L
Transmission: 4L60 w/Vigilante 2,400 Stall
Axle/Gears: Girdled 10 bolt/3.23's
Track prep can be huge! My best 60ft. with the Vigilante and 315/35/17 Nitto DR's is a crappy 1.83. This is at a track where they think good prep means a push broom and a few sprays of VHT from one of those hand held pump pesticide sprayers every 3-4 rounds. I might actually run a decent time if I ever get my butt out to Norwalk. The down side is I'll probably only get to make one pass.
Old Jun 22, 2006 | 08:58 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
hey sounds sorta like my track... lol
alright guys you have me feelin alot better. i was gettin to the point after 5 runs that it wasnt ment for me to beable to launch hard. lol i'll try to change up a few things based on what everyone has been tellin me
Old Jun 22, 2006 | 09:20 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Remember, your cutting these times in the middle of the summer, less dense air "doesn't give you as much power or torque"
I would suggest raising the pressure just a little bit. Most guys only run like 14-15 on slicks, a drag radial should be best around 24
Old Jun 22, 2006 | 09:33 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
my 60's been pretty consistant no matter the weather... mainly track prep difference. some nights have been better than others. weather starts showin up once i get on out past first gear... LOL
Old Jun 22, 2006 | 09:35 PM
Well when the track is hot, tires are stick, but you don't mph as much.
When the track is cold, you don't hook as well, but you mph more. It's wierd. I think you should say screw it and run slicks. have you swapped back to the 2.77s?
Old Jun 22, 2006 | 09:38 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
nope, i dont want 2.77s anymore. lol i want 3.42's that are in my 4th rear in the garage, and i want 17x11 grand sport Zr1's
Old Jun 22, 2006 | 10:31 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
some pics of the car with the wheels/tires on it
Attached Thumbnails Cant hook on ET STREETS on my L98-frontend.jpg   Cant hook on ET STREETS on my L98-frontquarter1.jpg   Cant hook on ET STREETS on my L98-tires.jpg
Old Jun 22, 2006 | 10:44 PM
mw66nova's Avatar
Engine: 7.0L
i love it!
Old Jun 23, 2006 | 05:34 AM
Demon355's Avatar
I want some DR's
I'd prolly snap my rear end to pieces though...
Old Jun 23, 2006 | 08:03 AM
mw66nova's Avatar
Engine: 7.0L
put in a set of lca relocation brackets and go to town my friend! your not making enough power to hurt that rearend.
just fyi guys, the lca relocation brackets are designed as a suspension tuning tool, not the mircale mod. they just happen to work really really well in my application. there are a few people who hook up better with them in the stock setting. make a few passes once you've got them on the car and see which setting the car likes the best. you'll know by the consistancy (or lack thereof) in your 60' times and which produces the best 60' times consistantly.
Old Jun 23, 2006 | 01:12 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
sounds like your rearend is bottoming out on the snubbers, if it hooks then spins..
Old Jun 23, 2006 | 01:14 PM
brutalform's Avatar
I remember back using them the first time, being used to 1.68s on the radials, then laying down some 1.75s with the ET streets. I was thinking to myself, "what the heck is going on here?" How hard are you against the converter when you launch?
Old Jun 23, 2006 | 01:25 PM
mw66nova's Avatar
Engine: 7.0L
if this is the case, then you'll need to get some lca relocation brackets, cuase the why the suspension moves with the lca relocation brackets, it plants the rearend into the ground instead of allowing all that squat. car should leave like this:
Old Jun 23, 2006 | 01:35 PM
Demon355's Avatar
I have ordered all my suspension pieces from UMI and I have LCA's, LCA brackets, Adj.Panhard bar, Wonderbar and SFC's. Mix that with the Eibach sportlines and new shocks and struts (and bushings throughout) my suspension is almost complete. Would I be able to run the DR's with that?
Old Jun 23, 2006 | 02:22 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
you should beable to run drag radials on that no problem
eibach prokit i guess isnt the best thing to drag race on, with 700+ lb front springs and progressive 108-170lb rears
as hard as i could get before the car started pushin thru. i'm gonna try alot lower and flash it more
could be with the shocks set so light on the rear... i am gonna try stiffenin them up abit. i have the LCA's on the bottom most hole. i might keep it that way or try next settin up to make it like factory--parrallel to the ground.
Old Jun 23, 2006 | 02:39 PM
mw66nova's Avatar
Engine: 7.0L
the straightline performance will be compromised with the sportlines. if you could get away with some ws6 or iroc springs, that would probably the best as far as trying to get good handling and good launching at the track.
Old Jun 24, 2006 | 11:30 AM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
what do you guys think is the best air pressure for BF Drag Radials. I'm running my car at the GMHTP Shootout on 8/1.
Old Jun 24, 2006 | 11:53 AM
mw66nova's Avatar
Engine: 7.0L
18-20psi is what i've gotten the best results at with my m/t's...though the m/t drag radial is a superior tire. you'll probably just have to play with it some...though i'd start at 20psi. since your looking for the absolute fastest pass you can get, you'll want as much pressure in the tire as possible to keep rolling reistance down.
Old Jun 24, 2006 | 12:29 PM
Demon355's Avatar
I'd have better launchs with my stock springs? Hmm...well I want a car thats both strip/street so the handling thing is a must. I'll just take whatever I get, not picky
You know my engine setup right? I'll be getting a 2800 stall along with the trans being beefed too, should help out alot. Still needs gears though...
Old Jun 24, 2006 | 12:46 PM
mw66nova's Avatar
Engine: 7.0L
yeah, i think that sticking with the stock springs would be the best bet...if you can sacrifice a little handling and put some stock v6 springs in it, that would be great for straighline performance...but would probably not do what you want for handling.
did you put your motor back together without replacing that one messed up piston?
Old Jun 25, 2006 | 08:41 AM
vwdave's Avatar
What converter do you have? Im surprised no one has asked this yet.
Old Jun 25, 2006 | 11:29 AM
Demon355's Avatar
I'm not keeping this motor and kinda wanted to frag it, lol! But I have the 350 on the stand-by if the 305 decides to die. It's not bad really, only a small portion is missing. I know it's not the best thing to do (build motor with bruck piston) but I don't really care
Old Jun 25, 2006 | 11:46 AM
mw66nova's Avatar
Engine: 7.0L
i just don't want to see it hurt those cylinder heads you just rebuilt...unless they don't matter either...
Old Jun 25, 2006 | 11:50 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
its an Edge Racing custom converter. 2800 stall...9.5inch... i dont know any other specs on it like STR or w/e
Old Jun 25, 2006 | 09:33 PM
its probably the 2.5 SR thats what i got, you can def. tells its a smaller converter over stock plus its alittle loser as well, but it gets the job done
Old Jun 26, 2006 | 02:49 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
i have had no complaints on this converter. i love it. i just wonder if i should have stuck with my original idea to try and get 2600stall instead of 2800. hurt alittle less on the topend i suppose. but overall, i'm happy with it.
looks like rain this wednesday....scattered showers so i'll see how the weather goes. i plan to race it again.
Old Jun 27, 2006 | 01:08 AM
Car: '82 Z28
Speaking of converters, I contacted Edge Racing about getting a converter from them. They recommended an STR of 2 or near 2? When I was looking up wtf STR ment, a page was saying that most stock converters are around the 1.9 to 1.95 range. So I would have thought that the number for my planned converter would be a little higher? I asked for a stall speed of 3500 to 3800.
edit, did some more reading and think I understand it now lol
Old Jun 27, 2006 | 02:18 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
yeah i'm not sure on all that stall stuff myself.
i do know i have some exhaust leaks around the header gasket as my bolts came loose again... so i tightened them all up again and it seemed to go away. more than likely they were loose when i went to the track last wednesday. so i might have lost abit of power there.
now i gotta grind abit off the header flange and or front a-arm since the two are touchin each other right now and it makes a awful noise.
Old Jun 27, 2006 | 10:03 PM
I think it's time to invest in some locking header bolts. Have you done any induction mods? I bet some SLP runners and a port matched plenum would give you 2-3 more mph in the 1/4. The runners themselves in stock form picked up about 1 mph and .1 et, and when I port matched them with a gutted box and K&Ns, i picked up 2 more mph and another .1-.2 et. AFPR would help also, mine runs best around 44 psi, Most like it around 48. Once you get those D.R.'s to hook, take a look at those mods. keep us updated 89, or throw me a pm if you wanna talk, good luck.
Old Jun 28, 2006 | 10:25 AM
brutalform's Avatar
Now, I'm confused! Are we talking ETstreet slicks, or ETstreet drag radials. I thought we were talking slicks. If we were not talking about the slick style, all of my posts were referring to the ETstreet slicks, and not the radials. I have never used the radials. Only BFG radials.
Maybe M/T should have given them (radials), a different name. Everytime someone mentions ET streets, I think of the origional ET street.
Old Jun 28, 2006 | 10:31 AM
mw66nova's Avatar
Engine: 7.0L
he's running the original ET Streets. look at the pics of his car in his other thread about getting the tires...
Old Jun 28, 2006 | 10:36 AM
  #42
brutalform's Avatar
Yea, Matt, thats what I thought. Other posters are saying "radials". I was sure that it was the originals.
Old Jun 28, 2006 | 01:50 PM
  #43
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
nope, not radials... DOT approved slick... the original ET street. car feels pretty strong today, even with the humidity and heat....i just finished making a home made ram air from the foglights, and i believe it really helps the car breath. i want to run it today but i dont think i'm gonna. we'll see.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Tarizza
Sep 24, 2015 12:57 PM
Doobie52
Sep 11, 2015 06:19 PM
