and yet another 1/4 time ?
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
what do you guys think this setup would and or should pull off at the 1/4 mile?
Car: 87 IROC
Engine: 406 sbc with Trick Flow heads, Hook
Transmission: Pro built 700R4
Axle/Gears: waiting on a new rear!!!!
Engine: ls1, LB9
seems very streetable with the manual trans. the brakes feel good unless you are just pumping them at idle then they get real hard.
I still have some tunning bugs to work out but, nothing too big.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
that should have potential to hit high 11's on great tire and good driving, but probly more like low 12's seems better. but it all depends on the heads.. what heads are you running on that thing? they better flow well to take advantage of that hsr and cam
i was thinkin of a similar combo with a cam like that and HSR but on a 383
Engine: ls1, LB9
I thought I put that in there.... well I will fix that right away, anyway they are afr 195 cc street heads they are the l98 angle plugs Joined: Sep 2003
Car: 89 Iroc-z
Transmission: TH400
well then, you should be good to go with that combo. i'd see 11s in there for sure if you can drive and hook up.
evilstuie
Jan 9, 2020 08:29 PM
Street Lethal
Apr 30, 2019 12:14 PM
