Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
dont know what i run
Old Sep 7, 2006 | 09:37 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
whats going on guys? My mods are listed below, I have open diff ( i know profile says different) and 308 gears. I also just got the custom chip in. seems to pull better at upper rpms but hesitates for a fraction of a second when just cruising off of a street red light. Before the chip I beat a 4.6 stang. He was stick and he could drive pretty decent. I pulled on the stang but didnt exactly kill him. from 10 mph to about 70 mph I had 1/2 -3/4 car on him. I am just curious about my time because there is this srt-4 that i want in my rear view mirror.
Old Sep 7, 2006 | 10:01 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
13s something
Old Sep 8, 2006 | 01:31 AM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
Maybe a 12.6 or somthin.
Old Sep 10, 2006 | 05:04 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
12.6? I hope you meant 13.6. With the stealth ram and open diff, plus highway gears I would say you're not getting near the cars potential. What year was the Mustang?
Old Sep 10, 2006 | 01:24 PM
Car: 92 Camaro
Axle/Gears: S60 373
stang
not exactly sure i am guessing at least 2000 it was a newer 4.6 the ones before they went retro. He still had 30 day tags on it though if that helps out.
Old Sep 10, 2006 | 01:27 PM
Car: 92 Camaro
Axle/Gears: S60 373
i just looked up my gears here either a 277 or 327
Old Sep 10, 2006 | 01:31 PM
Car: 92 Camaro
Axle/Gears: S60 373
so how much can i shave off using a eaton or auburn posi with say 373 gears?
Old Sep 10, 2006 | 01:32 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
without gears and converter, you'll be good to break into the 13's...
Old Sep 10, 2006 | 01:59 PM
Cam, Gears, Converter, and a tune you'll be in the 12's. The Mustangs after 98 are pretty fast, they make 260hp and with a 5 speed they're no push overs, you should have one covered with your setup as long as he's not substantially modded; even then you'll stand a good chance.
Old Sep 10, 2006 | 02:03 PM
Car: 92 Camaro
Axle/Gears: S60 373
would you advise a lt4 cam for my setup first or posi and gears before the cam?
Old Sep 10, 2006 | 05:24 PM
mw66nova's Avatar
Engine: 7.0L
get the current power to the ground more effeciently before you start throwing more power at it. the lt4 cam is super lame too. get something a bit nicer than that...like the cc306 cam or something.
Old Sep 10, 2006 | 06:15 PM
Agreed on working from the ground up, and agreed on the cc305 cam. The LT4 hot cam isn't a bad cam if you're on a budget but for a few dollars more you can get a more aggressive cam. If I had a Stealth Ram I wouldn't have bought the Lingenfelter cam I did.
Old Sep 11, 2006 | 07:05 PM
Car: 92 Camaro
Axle/Gears: S60 373
just curious, do yall have a part number on that cam? and when i replace the cam what else do i have to replace on the engine? thanks alot guys i know im asking alot of questions but i am defiantley willing to learn.
Old Sep 11, 2006 | 08:52 PM
mw66nova's Avatar
Engine: 7.0L
you'll need to upgrade the springs, and with that much cam, going to a full roller rocker wouldn't be a bad idea. p/n is: 07-306-8
Old Sep 11, 2006 | 10:23 PM
Car: 92 Camaro
Axle/Gears: S60 373
what about the computer? injectors? is the lift good or is it too much for stock?
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
