How bad or good ???
Car: 83 Camaro Berlinetta
Engine: 355
Transmission: TH350
Axle/Gears: ford 9" 411
How bad or good ???
Will the ford 9" kill any of my time? I killed the 10 blot posi and replaced it with a 9" ford. Looks like a lot more weight with the 9"???
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Probably and mostly from the added weight. The amount of HP lost through a diff would only be seen on a chassis dyno.
Don't forget that a 9" 28 spline axle is huge compared to a 10 bolt 28 spline axle and most people will go with a minimum of 31 spline. That's a lot more weight just with the axles. Your 83 would have had even smaller 26 spline axles.
