Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
14.230 @ 94.77
Old Oct 11, 2006 | 11:23 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
14.230 @ 94.77
how does that sound for a almost stock 350.
Mods: hooker comps 2460 (i had a local guy make the y, and i must say IT SUCKS) other than that stock from there back.
i had a BBK afpr, but the peice of crap broke while i was putting my new accel 23lb injectors on ( thanks *****)
bbk tb and MSD 6AL. ported penilum.
2500 stall and 373 posi.
Note: i made a 305 to 350 swap and a still have some things to get like the knock and ESC mod..
timing was at 12*
R/t .316
60' 2.006
1/4 14.230 @ 94.77
i noticed that my mph was up just a little after the injector swap even though i didnt have the afpr. i am also having bad wheel hop out of the hole.
my next mod will be sub conn. and some relocation brackets from S&W racecars. i still think that there is a tenth or two in some suspension work.
Old Oct 12, 2006 | 12:58 PM
zz4monte's Avatar
Car: 87 Monte Carlo ss
Engine: ZZ4 1.5 rollers 650DP
Transmission: Probuilt 700-R4
Axle/Gears: 8.5 GN 3.42
Do you have the stock runners and baseplate?The 3.73's don't do to much over 3.23 or 3.42 gears with that setup.I think alot of TPI guys have talk about this but I could be wrong.
Old Oct 12, 2006 | 01:24 PM
zz4monte's Avatar
That seems about right for a stock L98.Plenty of guys are in the 14.4-14.6 range stock.Low 13s are very possible just from boltons.
Old Oct 12, 2006 | 04:37 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
yea the 373s are a bit much for the stock setup. but i will be upgrading. i am thinking about going to 342 thought. if i get the TKO500 like i want ill be running some 308s
and yes the runners and base are all stock.
91 z28 350
Sep 26, 2002 12:59 AM
