Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Different ET's at Different Altitudes?
Old Oct 19, 2006 | 12:51 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
I always wondered, how come as altitude increases, your ET tends to decrease?
Old Oct 19, 2006 | 12:57 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
air is not as dense, so less oxygen means less power..
Old Oct 19, 2006 | 01:00 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
I think you meant that as altitudes increase performance decreases (but ETs actually increase). The reason for this is that the denser air existing at high altitude doesn't allow you to make as much horsepower. We have several regulars here that race at very high altitude and I am sure they will chime in too.
Here is an article to read from National Dragster: Weather Tech 101 National Dragster - Find Articles
Old Oct 19, 2006 | 03:52 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
my track is at 5800ft elevation, the air is just too thin so the oxygen content is decreased substantially. An engine is just a big air pump...so more oxygen=more power and vice-versa.
Old Oct 19, 2006 | 04:22 PM
I gotchya. I figured it had something to do with air being thinner, but I was never actually sure.
Old Oct 19, 2006 | 08:08 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Track altitude is just a reference. Racers keep track of the density altitude. With a combination of altitude, temperature, humidity and barometric pressure, the density altitude can change drastically hourly or daily.
Denver is officially 5800' altitude however the DA during the summer can put the air at an equivalent of 8000'. Watch ProStock cars when they go to Denver. At sea level, they're now running 209 MPH. MPH is a direct result of HP. In Denver, to my knowledge, I don't think a ProStock car has broken 200 MPH yet during a national event. That's a big HP loss because the air is thinner to mix with the fuel to make power.
Having a 12 second street car at a high altitude track is a fast car. A car that runs 12.9 in Denver is faster than a car that runs 12.9 in Florida.
When you think of a power adder such as NOS, blower or turbo. The purpose of them is to put more air into the engine. More air means you can burn more fuel. More fuel to burn means more power. Now a naturally asperated engine can only pull in the available air. At high altitude the air is thinner so there's really less air to burn. Less air and less fuel (need to keep the proper air/fuel mixture) means less power.
Old Oct 20, 2006 | 10:25 AM
five7kid
Carburetors
Sep 17, 2002 09:29 AM
Z-Man 85
Jan 20, 2002 03:21 PM
AlkyIROC
Theoretical and Street Racing
May 7, 2001 10:14 PM
AlkyIROC
ws6transam
Jan 31, 2001 07:18 AM
