ok ill jump in what do you guys thing my car will run
Car: 86 t/a
Engine: 383 sbc on nitrous
Transmission: Th350 with trans brake
Axle/Gears: 9in ford
ok what do you think my car will run this is just for fun, and see what you guys think, now i will type the long post lol.
Engine
383sbc
Forged crank and H beam rods, 11.1 Je nitrous pistons
zero decked and studed factory 010block
Ported Sportman 2 heads
Ported eddy vic jr intake with pro fogger
850 holley hp carb
hooker 1 3.4 long tube headers
Tranny
Race prepped Th350 with Pro Brake 3800 stall
Rear
9in ford 3.90 gears and spool
The car
full tube front susp with s10 box, aerospace drag brakes front and rear
sub frame connectors
battery moved to the back and any engine stuff removed that was not needed.
gutted dash and no heater.
Track height is 2750
o ya you can either do the engine off spray and on spray if you want, i have the fogger set to 350hp hit.
if you have any other questions please ask =]
Engine
383sbc
850 holley hp carb
Tranny
Rear
The car
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Do you have your competition liscence? Hard to say without the cam specs but I would assume you should be at least low 11s without anything too exotic (NA of course).
Car: 86 t/a
opps i new i forgot the cam specs lol .533 int .555exh 114lobe sep. adv int duration 312 and exh 322 but that is probley going to get changed to a bigger roller, but its a decent nitrous cam
Car: 86 t/a
no 1 wants to take a guess, my track is closed for the winter so its time to bench race hehe, and finsh a few more things on the car
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I would guess high 10's or low 11's on the motor depending on the weight of the car and traction....maybe low or mid 9's with a 350 n20 hit if you can keep it straight down the track.
86IROC112
Aug 17, 2015 02:00 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
